Need Outdoor Center Channel recommendations
wolfman1138
wolfman1138 Posts: 49
edited May 2012 in Speakers
Hi Folks,
Summer is approaching (or at least here in the NW the temps are above 60F) and I want to set up an Outdoor HT. I have a pair of Russound speakers with 4" drivers that came with the house and I picked up (cheap) a nice pair of Boston Acoustic Voyager VOYARK8T2R 8-Inch Rock speakers. (used as "hidden" surrounds as well as 5ch Stereo.)
I need/want a center channel that is weather-proof. I also plan on upgrading the (underwhelming) Russound speakers later, but budget wise, I want to keep things under control. This may sway people's opinions of what to recommend.
I'm trying to tuck under $250
I am considering either the Atrium 65 SDI or the 8 SDI because the come as a single for around the $200 point street price. The other option is to buy a pair of Atrium 5's and then use them as a center now and later use them to replace the Russounds.
Thoughts?
My Home Theater:
Mains: polkaudio RTi150
Center: polkaudio CS350LS (modified)
Side: polkaudio 65-RT
Back: polkaudio RC85i Rear
Sub: SVS SB13-Plus
Receiver: Denon 4311ci
Sony VPL-VW60 on a 92" Draper Premier screen
Sony 52" XBR2
Post edited by wolfman1138 on
  • ken brydson
    ken brydson Posts: 9,022
    edited May 2012
    Where are you at in the NW? Was checking CL today and saw a pair of Atrium 45's for I think $100. Can't remember where they were...
  • wolfman1138
    edited May 2012
    I'm near Portland, Oregon. I was a little hesitant on the Atrium 4's due to their 75Hz roll off. I like the idea of a little deeper sound.
    I also just found a pair of Atrium 6's for a good price (a few bucks over my budget...but hey, you gotta push boundaries sometimes.)
    My Home Theater:
    Sub: SVS SB13-Plus
    Sony 52" XBR2
