Third times a charm ?
JimKellyfan
JimKellyfan Posts: 696
edited May 2012 in The Clubhouse
Some of you may recollect, I once had a Sony STRDN1010 for my set up, blew the transformer, had it repaired kinda, and Sony eventually took it back. You would think I learned my lesson, right ? Well, Newegg had a sale on the next model, the STRDN2010, to which I bought, last October. Dang it if it didn't kick out the sub output, no signal coming from the receiver. I tested the PSW10 on an, RCA direct wired and worked fine, then on an old Soundesign, believe it or not, I have that with an array of old junk speakers in the garage when putzing about. It works just fine, as does the cable. So, Sony is sending me a label to get this second unit I tried fixed. So, I will be in the market for a home theatre set up, yet again. I have the Monitor 60's for fronts, the CS2 center, and will move the 40's to the back in my new endeavor. I am tossing between Pioneer, Onkyo or Marantz and in that order for the set up. Anyone having good luck with a similar set up or have a different receiver in mind for me to abuse and it takes it ? Funny enough, I hadn't been abusing the stereo like I had the first time around with the 1010 model. Guess that's why the main channels still work, ha. I also plan on getting something a little more potent from Polk that will handle the power from the Sansui, either the Monitor 70's or above. But, too, I have to give the Saansui a little love as well, maybe new or reman caps and get the level meters going. I am sure once I start taxing the old receiver, it may not like it so much without caps being redone or replaced. Hope all is well in polk land to my fellow polksters.
Onkyo TX-NR636
Main - polkaudio Monitor 60's
Center - polkaudio CSI A6
Sub - polkaudio PSW10
Sub2 - polkaudio PSW505
Surrounds - polkaudio Monitor 40 series II
Front Height - polkaudio Monitor 40's
Audio Outdoors
Pioneer VSX 406 - polkaudio Atrium 5
Shed
Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
Shed 2
Nakamichi soundbar
  • woodhead 2
    woodhead 2 Posts: 367
    edited May 2012
    My Onkyo has been running strong for three years
    Panny 8000 project
    Oppo 103D
    Fronts- Monitor 70's
    Upper fronts- Monitor 30's
    Surrounds- Monitor 50's
    Backs- Monitor 40's
    Center-CS 350
    Sub- SVS PB 2000
    Onkyo 607[back up]
