Nanners.......
Need some opinions on some good Banana plugs that you might have/had some experience with.
I really don't care for banana plugs if that tells you something so I am wanting some input on some of the better ones.
I am going to be using some pretty good wire, so I am looking for some pretty good plugs.
I will be using 16 ga. 6N OCC single crystal solid core copper wire, so they must be solderable.
I prefer spades myself, but in this instance will be using banana's.
Any thoughts/opinions?
I have used the Nordost Z plugs in the past with good results, but wanted some other direction to explore.
I prefer low mass, but would look at other types/coatings if you have some suggestions.
Much appreciated in advance.:cheesygrin:
Vampires from SonicraftMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
I like the looks of them for sure.
Looks just like the DH Labs.
7% taxes (I am in the same state), and probably $28.95 shipping knowing Sonic Craft (Dare me to share some experiences I have had with them:evil:).
You are fully aware my friend (we were in it together
Only problem is, I have not heard them, although I am sure they are contenders in this category.
I might, MIGHT I say:cheesygrin:, be looking at some of the silver/rhodium type.
Not a big fan of Rhodium either, but that said, you WILL gain the detail from rhodium, but at the expense of some other attributes.
Thats whats sux!
Nobody makes the perfect "anything"!
So it is a matter of checks and balances.
Considering I have never used this wire before, I am alittle scared to just jump into something, and would like to hear that "I tried such and such, and was super happy".Testing
Testing
Testing -
Radio Shack has some nice ones too.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Luminous Audio's nanners look pretty decent, and they are LOCKING!
Plus pretty low mass, and solderable.
The price is reasonable ($6.95).
I would be willing to spend any amount if someone has some ideas.
Money would be no object, considering the wire I will be using.
I am not out the price of wire, only the price of the "Nanners"!:cheesygrin:Testing
Testing
Testing -
Cables don't matter so why would the connectors?Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
I’M OFFENDED!!!! -
Nice................Now our grandchildren will be reading this thread:cheesygrin:!Testing
Testing
Testing -
Hello?
Tap, tap......tap........this thing on?
Testing........test...........123!
Oh OK, I guess nobody has every used banana plugs.
Sure...............
I can believe that.:eek:Testing
Testing
Testing -
I've used these before: Furez TST-SB60NP - at http://www.av-outlet.com/
I like them because they are pure copper, not copper plated. They are $15/pair. -
Something copper based such as Vampire or WBT.
Avoid Monoprice, Nakimatchi(or how ever you spell it), Rat Shack, etc..."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I am probably going to try those Ern Dog!
I think it makes sense to try several types.
Thanks for the link.Testing
Testing
Testing -
These...
I'll be getting some Vampire spades and nanners soon for some DIY projects. -
Hey pepster, where did you buy your Nordost Z plugs? I may give those a try. Thanks!
System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded
