Aragon 2007 Amp?
72RR
72RR Posts: 159
edited May 2012 in Electronics
Saw one that looked interesting.
I've not heard one so I'm looking for your input.
First of all, it would go into an enclosed cabinet so heat is an issue - that's why I've looking for a used Sunfire.
Sound wise how is it? I do maybe a 70/30 split HT to audio.
Price/value suggestions maybe?
It would be pushing a RT5000 setup right now (SDA in the future maybe, this site is gonna drive me crazy :smile:)
Post edited by 72RR on
  • DaveHo
    DaveHo Posts: 3,529
    edited May 2012
    Do you mean Acurus? And are you talking about the Klipsch owned era or the newer Indy Audio Labs models?
  • 72RR
    72RR Posts: 159
    edited May 2012
    Nope, Aragon.
    Best I can tell Acurus was the "value" line.
    It appears that the 2007 was introduced shortly after Klipsch bought them from Mondial and that Indy continues to support the earlier models.
  • Joe08867
    Joe08867 Posts: 3,919
    edited May 2012
    Hope you have the room for it? That is a beast of an amp. Can't really say anything about the sound of the 2007 but have heard a 2005 and thought it was very musical and clean. I won't say it was warm or sterile just very clean. Very NAD or Rotel sounding if you want a reference. Sounded better than Sunfire IMHO.
    I would guess the 2007 is similar.
    I also believe they are common ground and not built as mono blocks so it should be SDA friendly.
    images?q=tbn:ANd9GcRfTV_ByV13HkVdR6wI4mUUuOeQuzcBvFr2MZpu4pzTbuHgGysZ
  • DaveHo
    DaveHo Posts: 3,529
    edited May 2012
    You're right, my mistake. I think I remember reading before that though they carried the Aragon name, those amps were more along the lines of the Mondial era Acurus amps that preceeded them. At any rate, I've own both Mondial era Acurus & Aragon. Don't think you can go wrong.
  • 72RR
    72RR Posts: 159
    edited May 2012
    Any ideas on a fair price for it?
  • inspiredsports
    inspiredsports Posts: 5,501
    edited May 2012
    Not to derail, but is 72RR as in , "Beep, Beep" :question:
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • 72RR
    72RR Posts: 159
    edited May 2012
  • stubby
    stubby Posts: 723
    edited May 2012
    If memory serves me well, (?) they go for around $1700 or a little higher on A-gon.
    More derail........I have a friend with a beautiful 72 'runner with the 400 and 4 speed. Black with white strobe stripe over the roof. He bought it new.
    stubby
    SRS 3.1TL
    Harman Kardon Citation 5.1
    Anthem AVM2
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited May 2012
    I had the 2005 for a bit. I found it kind of bland and boring...nothing special.
    Good luck,
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • 72RR
    72RR Posts: 159
    edited May 2012
    Nice combination he's got stubby
    All I've got right now are automatics
