what are these?
leftwinger57
I'm not talking about the Ohm/Walsh speakers,I want to know what those chocks or blocks that suspend the speaker wires off the floor.This I've never saw in any store,set before today.Just for giggles enlighten me.
http://app.audiogon.com/listings/ohm-walsh-4-5000
H9 for the score!
+1, cable risers or the like. Designed to keep your cables off the floor. The benefits? Well, let's not start that, because that debate would be very much like an all star cable fest. And we don't need anymore of those!
You must have them to truly enjoy you listening experience.If you can't hear a difference, don't waste your money.
And to think ... This is part of the 22 miles of external wiring in the Space Shuttle. And if you look closely, some of it actually is laying "on the floor/deck"!
Can you imagine if the engineers had at least used "Wire Elevators" to keep some of these wire bundles suspended, how much better the Space Shuttle would have performed!
2-Channel Audio
Onkyo ... A-9050 . . .Integrated Amp. (Power Amp Section not Used)
Onkyo ... M-282 . ... Power Amps .(Pair)
Onkyo ... C-7030 . _.CD Player
Polk . . *. RTi A7 - ....Front Speakers
Polk . . *. RTi A3 - ....Rear Speakers -
chn,your right about starting a new debate about something. I did read the article that H9 provided.I don't buy it for a minute. I quess whomever's $1200 speaker cables need suspenders all power to ya.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
I'm surprised they even got it off the ground, those uncouth barbarians!design is where science and art break even. -
Well, they did get it off the ground, we'll give 'em that. But it didn't sound very good.
What kind of music does one use to do the Space Shuttle, is it kind of like the Texas Two Step?
That wiring was probably good enough for the Bose Sound System. I bet the cost for the system was astronomical.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
I loled. :cheesygrin: -
You should give 'em some break-in time :biggrin:Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000 -
Says Robert F. Levi of pf audio DISCOURSE:
"The Dark Field Cable Elevators cost $350 and come in a set of 12 which will do the job in most setups. They are very stable and hold all kinds of cables and power cords without any slippage or wobbling. I elevated my entire system of cables with one box of lifters. They replaced my home brew modified plastic cup setup that was effective, but required tape to hold the cables in place. The Dark Field elevators are set and forget...
"...Their effect in a system is not subtle …improvements will be heard across the board. If you don't use cable elevators, you will be truly shocked at the improvement in quiet and definition with the Dark Field. If you do use elevators, chances are these will still make some improvement. I've got a ton of home brew cable elevators for sale cheap. Well done Shunyata! The Dark Field Cable Elevators are highly recommended."
Well...........I think these are JUST what I've been looking for for my 2-ch system (vintage Onkyo TX-2000 receiver and a pair of Polk S4s) in my laundry/puttering room! -
Marketeers can get pretty over the top when describing effects of their gadgets for the audio crowd. While cable elevators serve a purpose, it's effects can be zilch to slight in my experiences anyway. The idea is to keep your cables from gathering static by laying on the floor/carpet. Even a well shielded cable on a wool carpet will collect static, which can add noise. Now whether or not thats audible is going to be like a cable debate.
350 bucks ?? Oh hell no. You can make some yourself out of blocks of wood or buy the cheaper ceramic ones. I've even seen some who just use a paper cup upside down with a slit on the top for the cable. Looks ghetto but still serves the purpose. Part of these elevators are for looks to show off your 2000 buck cables, and another part to reduce the effects of static. Money that could be spent elsewhere in your system for better returns imho.HT SYSTEM-
lsi 9's -
We have extreme static electricity problems where I live, so I use porcelain cable elevators to lift my speaker cables off the carpet. Do they improve the sound? I don't know...but they sure make me feel cool.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
And to think, those high dollar cables need risers. To shield them from static electricity? For the price of some I would think that would be a non issue.--Gary--
and the ad was from the maker ,not a review.that was fun, great answers from you dudes.high $ cables indeed .2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Well, SignalCable makes some decent looking ones if someone really wants to get em. Price isnt bad, we get a discount too.....
Part of my wants to get them just because lol....
http://signalcable.com/cableriser.html"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I showed these to Dr. Habib ("Huh-beeb") at work today - I think most CP members would consider him an audiophool considering some of the gear he has - and even he said, "OMG! Give break to me!" :eek:
Some time ago, I linked an industrial place where you could buy the porcelain isolators from cheap (like $5 bucks each). You'll have to search for it. If you look at my showcase, you'll see them. Audio stores were charging around $25/ea for these very same isolators.
Try: http://www.polkaudio.com/forums/showthread.php?100408-Speaker-cable-elevators-arrived...pics&highlight=cable+elevatorsSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
When I built my acoustic treatment stands I incorporated cable risers in them. Multiple slots to keep power, Cat5 and speaker cables separate and off the floor. Like Pparacchin with the Ohm's, I have hardwood floors and risers make it easier to clean under the cable when we run the Swifter Sweeper around. A fellow at a high end audio store once told me ignorant folks are less likely to step on an elevated cable versus one lying on the floor. YMMV
EDIT: Steve, if folks are dishonest, observant, and go to neighborhoods where the local Con Ed is installing new power poles, they can snag them for free after the pole is delivered (before it is put up of course).:eek::cheesygrin:
Oh, and I don't stutter and wonder why I see multiple 'power' words in the first sentence when I only typed one....althought there are more than one in my system.:cheesygrin:Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote: »When I built my acoustic treatment stands I incorporated cable risers in them. Multiple slots to keep power, Cat5 and speaker cables separate and off the floor.
Pics por favor!"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »Pics por favor!
This is the best I can do for now (at work). From my showcase. I may have some close ups at home. There are notches at the front and back of stands for two pairs of speaker cables to each speaker (ESL panel and woofer), one power cord to each speaker (ESL transformers), power to amps and long IC's to the gear rack.
