Pulling in wifi signal
brgman
So next month i go back to a place in the VA mountains we go to a couple times a year and although there is a wifi signal we can get it usually is weak.Is there any device out now that will pull this in better so we can use a laptop and xbox better?
I’M OFFENDED!!!!
I’M OFFENDED!!!!
Post edited by brgman on
Usually 2.4Ghz is the frequency for the wifi signal. But there are some 5Ghz signals now. So it would be best if you could check which frequency you need. Several questions come to mind. Does this need to be an antenna that connects directly to your laptop or xbox? You will need to match the connectors and they might be different between the two devices. Powered or unpowered antenna? ethernet connection, then you might need an access point and antenna. Could also look at wireless amplifiers.
http://www.l-com.com/category.aspx?id=2073
http://www.l-com.com/productcenter.aspx?ID=303
http://www.l-com.com/productcenter.aspx?ID=2018 -
Imagine sitting in a hotel with crappy wifi signal.I'm wondering if there is an amplifier for lack of a better term that would grab the signal and then give me a better signal thru the "amplifier.
I guess getting a usb antenna would be about all i could do.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
You can get a range extender/wireless repeater.... Even cheaper routers now have this function for less than $35
I like getting a router with the functions rather than a specific repeater because you get a hub with it if you want to connect things with an Ethernet cable.Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub -
You can DIY a directional antenna, just google it. Or buy one. For that to work, you need to be in a situation where you can actually pinpoint where the signal is coming from.
Plan B: cat-5 is cheap. Buy a roll and just temporarily run a line (assuming this isn't a stealing-from-the-neighbors kinda party).Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
most people go to the mountains to get away from the XBox'es, WiFi's, cell tower signals, etc. lolPolkFest 2012, who's going>?
danger boy wrote: »most people go to the mountains to get away from the XBox'es, WiFi's, cell tower signals, etc. lol
I'm not most people!
You want to keep a 16 year old boy entertained 24/7 for 10 days.Have at it my friend,have at it.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Oldfatdogs wrote: »Find that boy a 16 year old girl!Done
Great idea.I hope she has an 18 year old sister.
Although the wife may frown on that.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Good luck to you both.
Sorry for the derail.
