Polk PSW 505 180 plus shipping if required.
logo896
Amazing subwoofer for this price point. Here are the specs if your not familar. This is a great subwoofer for home theater and filling large areas. Lightly used for only about 10 hours. Descided to go back to my 2 channel roots and drop the hometheater set up. Finished in black.
Comes with orginal box and manual. I recently bought this off ebay about 2 months ago so just trying to cut my losses. Thanks.
Logan
Driver Complement
Subwoofer 1 - 12" Diameter (30.48cm)
High excursion polymer composite cone with hi roll surround, shielded
Electrical
Overall Frequency Response 23Hz - 160Hz
Lower -3dB Limit 28Hz
Upper -3dB Limit 125Hz
Crossover Variable low pass 60 - 125Hz, 4th order
Inputs Speaker level 5-way binding posts, line level (filtered) and LFE (unfiltered)
Outputs Speaker level
Dimensions
Cabinet Size 16-1/8" H x 15-1/8" W x 18-3/16" D
(40.96cm H x 38.42cm W x 46.20cm D)
Enclosure Type Vented via slot loaded port
Subwoofer Amplifier Specs
Power Output 300 watts Continuous Average Output
Dynamic Power Output 460 watts
Shipping/Other
Shipping unit: each
Total Shipping Weight 48.00 lbs. (21.77kgs)
Logan
Driver Complement
Electrical
Dimensions
Shipping/Other
Shipping unit: each
Post edited by logo896 on
