MW-6503's ordered
transmaster
transmaster Posts: 428
edited May 2012 in Vintage Speakers
I see what you mean about Polk Audio, They answer their own phones. Good thing I an a Polk Club member Wyoming gets sales tax on this purchase with free shipping I still came out ahead $100.80 for the two drivers.
Radio Station W7ITC
Post edited by transmaster on
  • canadianicon25
    canadianicon25 Posts: 200
    edited May 2012
    when you get them be careful to cut the rubber that slightly covers the screw holes.
  • transmaster
    edited May 2012
    Will do have been fore warned about this issue.:smile:
    Radio Station W7ITC
  • hangon
    hangon Posts: 228
    edited May 2012
    I am wondering if they look exactly like the original MW6503.
    I am in need (1) my self for my SDA-SRS and I do not
    want to have one look out of place.
    When you get them please let me know.
    HT Theater
    SRS-SDA 2.3tl RDO's
    Custom Center made out of a RTA15tl
    Pioneer Elite SC-25 Receiver
    CineNova Grande 5 channel Amp
    Klipsch KA-1000-THX Sub Amp
    (2)Klipsch KW-120-THX Subs
    Basement System
    SRS-SDA 1.2 upgraded Xover
    ADCOM GFA 5500
    ADCOM GFA 5503
    Yahama P7000S Pro Audio Amp
    dbx 120x-ds Sub-harmonic Synthesizer
    2-JBL 4645C Subs
    1-Paradigm SW2200 Sub
    Klipsch Reference in wall's
  • transmaster
    edited May 2012
    The only difference is the two connection points where the two wires go down to voice coil are not visible from the front
    Radio Station W7ITC
  • TennMan
    TennMan Posts: 1,266
    edited May 2012
    hangon wrote: »
    I would find a good used one for a replacement. I think you will notice the difference in them with one new one mixed in with all the old ones.
  • transmaster
    edited May 2012
    hangon wrote: »
    TennMan posted these photo's on an earlier thread the one on the right is the new MW-6503
    Radio Station W7ITC
  • canadianicon25
    edited May 2012
    more words when it comes to cutting the rubber from around the screw holes. be careful! when i did mine it actually pulled the surround off. seems like weak glue. i ended up having to crazy glue them back together.
  • transmaster
    edited May 2012
    I am going to open up the holes with a hot soldering pencil
    Radio Station W7ITC
  • hangon
    hangon Posts: 228
    edited May 2012
    I am still waiting for someone that has an extra MW6503 to sell/trade me one.
    I am willing to trade one SL3000 for one MW6503.
    HT Theater
    SRS-SDA 2.3tl RDO's
    Basement System
    ADCOM GFA 5500
    ADCOM GFA 5503
    2-JBL 4645C Subs
  • transmaster
    edited May 2012
    I found Polk uses a silicone rubber for the surrounds, very nice. My solder pencil was not hot enough to even touch the stuff. I noted the originals the have cut outs where the mounting hole are in the spider I could do this with an X acto knife but I am not going anywhere near the speaker cone with one. What I did is use a larger head screw to mount the speakers they tighted down nicely and did not move the rubber at all.
    The sound: Sharper ears then I have mgiht be able to tell the difference but I sure can't. I mounted both of the new drivers in the 10B that had the roasted units. I pulled up "The seduction of Claude Debussy" (1999) performed by The Art of Noise and played track # 4 "On Being Blue"" It starts with very deep zoom bass. I like this track for testing woofers as you hear both sides trying to reproduce this deeply decending glissando at the same time it gets so deep it actually sets up a vibration in the room you can actually feel. Listening to this I could not tell the difference between the new and the old.
    Radio Station W7ITC
    heiney9 Posts: 25,217
    edited May 2012
    That's an excellent track as well as an excellent cd. Don't hear a lot of talk about "The Art of Noise". Not a common band (of you could call them that) that gets discussed.
  • transmaster
    edited May 2012
    heiney9 wrote: »
    I have their entire discography, and you are correct you really can't call them a band. The Seduction of Claude Debussy is my absolute favorite. It is a great recording to test speakers with. Orchestral, Operatic, hip-hop, ambient, soft jazz, it is all there.
    What is interesting is the 1st Onkyo TX-NR709 I received from Crutchfield failed while I was listening to Seduction when "On Being Blue" started the right channel let loose and destoyed the Woofer on the right hand Warfedale W35. It sounded like a jackhammer just before it died, and the protection in the Onkyo shut everything down.
    Radio Station W7ITC
  • Shacky
    Shacky Posts: 113
    edited May 2012
    Glad to hear th new drivers sound good.
    I have Art of Noise Ambient Collection from '90. Will have to look for the DeBussy CD :cool:
  • transmaster
    edited May 2012
    Amazon has the CD, They are very proud of the price for a new CD, but they do have used ones for mucho cheaper.
    Amahttp://www.amazon.com/Seduction-Claude-Debussy-Art-Noise/dp/B00000JHCT/ref=ntt_mus_ep_dpi_8
    I am am at home listening to Seduction as I type, and the track I was thinking of is track #3 DREAMING IN COLOUR, not track #4 I continue to be astonished at just how good these Monitor 10B's sound.
    Listening this it dawns on me just how much like Ken Nordine's "Word Jazz" parts of Seduction are
    Radio Station W7ITC
  • TennMan
    edited May 2012
    Monitor 10Bs are great speakers. Monitor 10Bs with SDA crossovers (like mine) are amazing speakers!!
    I'm going t be looking for the CD suggested.
  • Shacky
    Shacky Posts: 113
    edited May 2012
    Thanks Transmaster! I just ordered it.
  • transmaster
    edited May 2012
    Shacky wrote: »
    I never get tired of listening to "Seduction". I have all 39 releases of Art of Noise and while there are a number of others that are very good The Seduction of Claude Debussy is the best.
    Radio Station W7ITC
