Dead Denon?
928man
928man Posts: 71
edited May 2012 in 2 Channel Audio
Bought a Denon AVR4800 cheap at a garage sale this past weekend. All functions seem to work well: accepts and sends video signal; recognizes audio inputs; remote and on screen functions work. Just no sound! Is it worth fixing?
Any ideas on problem?
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited May 2012
    Open her open and take a look around, look for anything which looks odd.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • codyc1ark
    codyc1ark Posts: 2,539
    edited May 2012
    Is there a speaker on/off button? Like an a/b or something... Other than that, open it up and start hunting for fuses.
  • transmaster
    transmaster Posts: 424
    edited May 2012
    If this is like a lot of these home theater receivers you can designate how given function is supplied. It is possible the input you are using has been configured for a digital feed. Try plugging into some of the other inputs to see if it will make noise for you.
    Radio Station W7ITC
  • ambiophonics
    ambiophonics Posts: 729
    edited May 2012
    I would suggest performing a factory reset before trying anything more drastic. I've seen several Denons in my shop respond positively after this. Search the PDF manual for reinitialize, reset, default, etc and it will guide you through the process. Who knows how the previous owner had the unit configured. Good luck!
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
  • skrol
    skrol Posts: 3,490
    edited May 2012
    I believe there should be some fuses inside. That was quite a receiver in its day. I have PDFs of the product sheet and owners manual. PM me with your email if you would like them.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
