Spikes for SDA 1C ???
nhhiep
nhhiep Posts: 877
edited April 2012 in Vintage Speakers
I don't have a drill or feel like using a hammer to install spikes/feet to my SDA 1C. does anyone know where I can get the type of spike that I can install by using a screw driver? SDA 1Cs don't look stable on the carpet.
I like the feet from the Rti A series, how do they install? anyone has a close up picture?
Post edited by nhhiep on
    heiney9 Posts: 25,217
    edited April 2012
    Forget it if you can't do it right. 1C's are much to heavy for a cheap "screw in" spike. The first time you go to move them or pivot them you'll have trouble.
  • sda2mike
    sda2mike Posts: 3,131
    edited April 2012
    edited April 2012
    Macrame hangers
    SCompRacer Posts: 8,513
    edited April 2012
    heiney9 wrote: »
    +1 to that. Oak bottoms? I wouldn't put a screw of that size in without drilling a pilot hole either. You risk causing the wood to split, not to mention the difficulty turning the screwdriver and possibly stripping the head of the screw out without a pilot hole.
    edited April 2012
    Most of the 1C's (non studio) not sure what the op has are real oak veneer over particle board. Although I do understand some early 1C's had real oak, not sure if they are all that common. I know the SRS's and SRS2's were mostly oak end caps, but the 2B's and 1C's were mostly oak over particle board. The OP should check for sure.
    My 1C's are oak veneer over particle board.
    If the OP has studio's that would be even worse.
  • nhhiep
    nhhiep Posts: 877
    edited April 2012
    mine are just veneer over particle board (not real wood), so using a screw driver should be easy. I just don't trust myself using a hammer, probably do more damage to the drivers at the end.
  • sda2mike
    edited April 2012
    you would'nt use a hammer anyway...if you're gonna do it - do it right...use a drill...don't forget the hot glue, too...sounds like you'd be better off finding a handy buddy to help you...if i was in your area, burgers and beer would get your install
    edited April 2012
    nhhiep wrote: »
    What kind of spike allows you to just screw them in?
    I beg of you to do it right even if you just get this basic kit from Parts Express.
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=240-717
    P.s. Not to mention banging on the cabinet with a hammer might be a good way to shift one of the magnets in a driver.
    F1nut Posts: 50,755
    edited April 2012
    You can not install a T-nut or treaded insert like in the Parts Express link without drilling a hole first.
    They are screwed on....into a treaded insert, which had a hole drilled first.
    Bottom line, you have to drill a hole.
  • thsmith
    thsmith Posts: 6,082
    edited April 2012
    To addon, if you measure the depth the Tnut needs to go into the cabinet and use a drill stop to that depth you will not have to drill all the way through the bottom. At that point you can gently tap the tnut into the bottom.
    Start here for how I did mine. http://www.polkaudio.com/forums/showthread.php?82792-To-Spike-or-Not-Spike-1.2-TL-s&p=1077485&viewfull=1#post1077485
    F1nut Posts: 50,755
    edited April 2012
    Damn, I can't spell today. Make that "cannot" and "threaded".
  • ken brydson
    ken brydson Posts: 8,785
    edited April 2012
    Turn in your man card. Don't own a drill... seriously? Surely you have a friend or neighbor with one.....
  • WastelandWand'r
    WastelandWand'r Posts: 466
    edited April 2012
    Screw In?
    Why when you can take the 'liquid coupled' passive radiator out and just nail thru them into the floor.
    Secure, not unsightly like some of the other recommendations, and if secure is what you are looking for you just did it.
    I would use a large galvanized nail to add some color and pizzazz to it.
    Or drill a hole, tap a t-nut into it, and screw in some spikes.
    Happy trails,
    Nathan
    Home Rig
    SDA 2.3TL's front and center
    Polk 1000p Center
    Pioneer Elite SC35 Receiver (Pre/Surround
    Sunfire Cinema Grand 5X200-Back in the mix.
    OPPO BDP-93
    Squeezebox
    Stepped up to name brand Speaker Cables and interconnects!
    Monitor 4, 5, 7, 10's, SDA 1B's, 2B's, 2.3TL's, RTA 15TL's all in storage waiting for me.
    Sales Rating #1!!
  • chandler9a
    chandler9a Posts: 878
    edited April 2012
    To the OP, I did this to my 1C's a couple weeks ago and you definitely want to take the advice above. Drilling a pilot hole is very easy, just measure how far you need to go in, put the T-nuts in and install the spikes.
    thsmith's thread above is what I went by, great way to do it.
