Anyone on here custom building SDA IC's?
dpowell
dpowell Posts: 3,068
edited May 2012 in Vintage Speakers
I need a custom Pin/Pin SDA interconnect and wondering if anyone on the forum is building them these days?
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
Post edited by dpowell on
  • brgman
    brgman Posts: 2,859
    edited April 2012
    pepster
    I’M OFFENDED!!!!
  • Mr. Bubbles
    Mr. Bubbles Posts: 736
    edited May 2012
    consider bypassing and sealing the Interconnect socket, adding an extra set of good binding posts and using the same quality speaker wire you are using for the mains runs. It makes a HUGE difference.
  • thsmith
    thsmith Posts: 6,082
    edited May 2012
    +1, wish I had done it sooner.
    nooshinjohn Posts: 25,464
    edited May 2012
    The 2.3TL's are pin/blade Doug...
  • dpowell
    edited May 2012
    Ooops, yeah. Not sure what I was thinking or distracted by when I wrote that! :) Pepster is making me a cable. The only speaker cable I have that is 20' long is M!@#$ter and I refuse to use that unless absolutely necessary.
    edited May 2012
    No worries man... You've had a rough day!:wink:
