How does this sound?
JDOGG
JDOGG Posts: 433
edited October 2003 in Electronics
Would a Harman Kardon AVR 230 with Infinity Primus 360's for fronts(towers) and 160's for surround with a C-25 center sound good for music and ht?any polk ones same price sound better? Need suggestions on a moderately priced sub too. Thanks in advance.
Panasonic VIERA 46" 1080p plasma
Onkyo TX-SR805
Klipsch RF-7(bi-amped)
Klipsch RF-25
Xbox 360 with HD DVD
Playstation 3
Cobalt Cable
Post edited by JDOGG on
  • Frank Z
    Frank Z Posts: 5,860
    edited October 2003
    Knowing your speaker budget would help. It's kind of difficult to recommend a speaker if we don't know how much you can afford.
  • JDOGG
    JDOGG Posts: 433
    edited October 2003
    Up to $800 on fronts, going to get them first with receiver then upgrade rears, center,and sub later.
    Onkyo TX-SR805
    Klipsch RF-25
    Playstation 3
    Cobalt Cable
  • fireshoes
    fireshoes Posts: 3,167
    edited October 2003
    Well, since this is a Polk forum, try the RTi8' with the cherry finish. ;)
  • Frank Z
    edited October 2003
    I've never been a big Infinity fan, so take my comments with a grain of salt. You've probably found that the Polk speakers are going to cost a bit more than the Infinities your looking at. But I think you'll find that a matched room full of Polks is hard to beat. If you have to, save up and get the Polks. Doloar for dollar, they are tough to beat. Note for note they sound better than alot of the more expensive speakers available today.
  • JDOGG
    JDOGG Posts: 433
    edited October 2003
    do know a place on the net where i can get them heaper than crutchfield?(699.98)
    Onkyo TX-SR805
    Klipsch RF-25
    Playstation 3
    Cobalt Cable
    VR3 Posts: 28,782
    edited October 2003
    Go to Yahoo Shopping and type in the model number. Cheaper you will find.
  • fireshoes
    edited October 2003
    Don't forget to make sure that it is an authorized retailer before you buy (almost zero online will be). When you buy from unauthorized dealers you forfeit the five year manufacturer's warranty. Also you will want to require the speaker shipment be insured in case of damage.
  • JDOGG
    JDOGG Posts: 433
    edited October 2003
    Thanks for all the help guys.
    Onkyo TX-SR805
    Klipsch RF-25
    Playstation 3
    Cobalt Cable
