surrounds
I have been looking for a pair of RT7s or RTi35s as new surrounds to go with my RT55 and RT7(dual center setup) and have run across a pair of RT5s. Anybody think I'd be ok with them as surrounds? or should I keep looking for the 7s or 35s? I'm hoping to not spend over 200.
Thanks!
Brad
Thanks!
Brad
Post edited by brussell on
The new RTI5/7 will not be the best match to your set, the RTI38 would be the same as yours and would be the best choice in my opinion. Get the 38's if you still can.
Dave -
I know the five has a silk dome tweet that doesn't match. But the tweet in the 38 doesn't match either. So could you elaborate a little more? BTW I'm the RT5 is a mid 90's vintage speaker not a new one.
Thanks! -
The CC in Johnstown,PA has the Fxi30's for $81 each on clearance. The store is located in Western PA. I can probably get you some store info if needed.Receiver = Denon AVR-3803
DVD = Denon DV-2900
Fronts = SDA SRS 2.3TL's
(Carver m1.5t)
Center = CSi40
Side surrounds = Fxi30's
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Pioneer SX-1050 receiver
Rti38's -
thanks for all the advice. just picked up a pair of fx/500s
