SDA 2.3 and audio research tube amp
mortonn
mortonn Posts: 4
edited April 2012 in Vintage Speakers
Just got a Pair of sda 2.3's. Was unsure how to connect them to audio research classic 60 amp. SDA speakers apparently have to be connected differently ARC tube Amps because of the common connection between the two speakers. I could not find this in the forum so I called Audio research and they told me to connect the negative speaker wire to the 4 ohm output on the amp as this output is internally grounded and then connect the positive speaker lead to the 16 ohm amp output. If you require an inverted signal then connect the positive speaker lead to the 0 ohm output. According to Audio research all their products are non inverting so if you are using Audio research amp and preamp then use 4ohm and 16 ohm amp outputs. Failure to connect in this way could short out amp.
Post edited by mortonn on
  • drumminman
    drumminman Posts: 3,396
    edited April 2012
    Not familiar with their equipment, but if that's their recommendation I'd follow it. I'm assuming that ARC is familiar with SDA speakers and their requirements.
  • Schurkey
    Schurkey Posts: 2,104
    edited April 2012
    mortonn wrote: »
    I don't understand how an output can be grounded.
    If that's what the manufacturer says, do it. I'm just saying that it does not make sense to me.
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited April 2012
    Hello,
    Welcome to Polk's forum. I looked at the amp's schematic and the 4 Ohm tap is at ground potential, so follow their recommendations. That kind of output configuration is very common with ARC amps. You should have excellent performance with the speakers and amp.
    Cheers, Ken
  • mortonn
    mortonn Posts: 4
    edited April 2012
    Hooked of speakers as ARC told me to do, Powered it up and no smoke just some great sounding speakers. I thought the ARC classic 60 may be a bit too small power wise for these speakers but I was wrong. Thanks for replies
