SDA2 Replacement Parts
Power13
Power13 Posts: 15
edited April 2012 in Vintage Speakers
I received a pair of SDA2 speakers a couple of years of ago. Considering there age I worry about the components being tired out. I'm not sure how to figure out what replacements are compatible (i.e. new tweeters etc). Also is installation rather simple. By that I mean I would I be able to simply solder the connections to the new components and be good to go? I appreciate the read and comments!
Post edited by Power13 on
    F1nut Posts: 50,755
    edited April 2012
    If you have a picture or can describe them very well it will help us help you.
  • Marty913
    Marty913 Posts: 760
    edited April 2012
    As F1nut said, it would be very helpful to know exactly what SDA2 speakers you have (SDA2/A/B) if you want specifics. All are upgradeable, and yes it essentially comes down to de-soldering/removing old components and soldering in new ones - plus probably replacing tweeters. There are other optional upgrades like rings, interconnects, spikes, etc. but it all starts with what model you have. Doing a forum search on "SDA2 XO" should get you started.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • Power13
    Power13 Posts: 15
    edited April 2012
    I'm away at school for a few more weeks but I found a picture in another thread:
    http://www.polkaudio.com/forums/showthread.php?131390-What-SDA2-s-are-these-Worth-275
    These are exactly what mine look like so that would make mine SDA2-B. As suggested I think tweeters is probably where I will start. From what I read on here people seem to recommend the rd0-194. Can I get these through Polk or do I need to find them through a dealer?
  • bmbguy
    bmbguy Posts: 416
    edited April 2012
    You can get them directly from Polk. Call them, (number up above) and tell them you're a CP member to get a discount.
  • Power13
    Power13 Posts: 15
    edited April 2012
    ^ thanks. Also I was curious and can't seem to find what wattage the SDA-2B are rated for at 8 omhs?
  • bmbguy
    bmbguy Posts: 416
    edited April 2012
    Power13 wrote: »
    I am hardly a font of Polk knowledge compared to many others around here, but I do happen to have some info on the 2B in a copy of an old Polk brochure I ran across on the web - although the brochure says "Rec. Amplification", which I assume to mean 'recommended', which isn't a 'maximum':
    Rec. Amplification 30-350 Watts/ch. 'Nominal impedance' is 6 ohms. Efficiency: 89.7 db.
  • Power13
    Power13 Posts: 15
    edited April 2012
    So would those wpc numbers be lower with a higher impedance? My receiver puts out 2ch. at 8ohms.
  • Power13
    Power13 Posts: 15
    edited April 2012
    Power13 wrote: »
    I should say my the wpc of my receiver are listed for 8 ohms
    F1nut Posts: 50,755
    edited April 2012
    You should consider doing the TL upgrade to your 2B's. You might also want to consider using something other than a receiver.
  • bmbguy
    bmbguy Posts: 416
    edited April 2012
    Power13 wrote: »
    You need to make sure your receiver will tolerate a load less than 8 ohms. But in general, yes -- most amps will deliver more power to a lower impedance load. But they must also be capable of delivering the higher currents that will be drawn by that lower impedance load. Some receivers are not.
    If the manufacturer specifies that you shouldn't connect a speaker with an impedance less than 8 ohms, then you probably shouldn't!
  • Joe08867
    Joe08867 Posts: 3,919
    edited April 2012
    What receiver do you have? Some can do more than they list in the standard specs.
  • Power13
    Power13 Posts: 15
    edited April 2012
    I definitely will be upgrading to some sort of power amp but can't at the moment. Can I get the parts for a TL upgrade through Polk (trying to get an idea of cost).
    bmbguy wrote: »
    The manufacturer only lists 8ohm impedance wattage, I assume since this tends to be the most common for speakers. They don’t mention any warnings about connecting anything with less and I haven’t had any issues with my receiver/speaker combo.
    Joe08867 wrote: »
    Sony STR K750P nothing special but I have been working on a college budget, but finishing in a few weeks so hopefully I will be able to upgrade my setup soon.
    F1nut Posts: 50,755
    edited April 2012
    http://www.polkaudio.com/forums/search.php?searchid=775058
    That's because it isn't rated for anything else. That said, you can use it to power your 2B's, just don't expect much and don't crank it.
  • bmbguy
    bmbguy Posts: 416
    edited April 2012
    Power13 wrote: »
    Looks like the back of the receiver specifies a load of 8-16 ohms. That implies that they don't 'officially' support lower impedance loads.
  • Power13
    Power13 Posts: 15
    edited April 2012
    bmbguy wrote: »
    I haven't had any over heating or clipping on part of my receiver. Eventually I'm going to ditch the receiver for a power amp to go along with my Rotel RC-1070. I'll definitely get something more 6ohm friendly at that point in time
  • bmbguy
    bmbguy Posts: 416
    edited April 2012
    Like F1nut said, it'll probably be fine as long as you don't overdo it. Just something to be aware of.
    Enjoy the 2Bs! Duh - of course you will!
  • Power13
    Power13 Posts: 15
    edited April 2012
    bmbguy wrote: »
    Appreciate you both answering my questions!
