What are these
Crashdot
Crashdot Posts: 182
edited April 2012 in Vintage Speakers
I tried looking up "polk monitor series III" which is how they are described, but got no results.
Post edited by Crashdot on
  • gwg_97
    gwg_97 Posts: 332
    edited April 2012
    RTAs. Maybe RTA8s?
    System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded
  • 11tsteve
    11tsteve Posts: 1,166
    edited April 2012
    post a pic with the grill cover of....the should be a tag in the upper corner on the back?
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • falconcry72
    falconcry72 Posts: 3,580
    edited April 2012
    11tsteve wrote: »
    This.
    They look bigger than 8's, maybe 11's?
  • transmaster
    transmaster Posts: 428
    edited April 2012
    I believe these are Polk Audio Monitor Series RTA-8T Towers.
    http://www.polksda.com/rta8t.shtml
    However it is difficult to gauge the size in the photo here is the RTA-11T
    http://www.polksda.com/rta11t.shtml
    A look under the speaker grills will tell the story.
    Radio Station W7ITC
  • agfrost
    agfrost Posts: 2,430
    edited April 2012
    Crashdot wrote: »
    Might the seller have misread "11T" as III? They are RTAs of some variety.
    Jay
  • transmaster
    edited April 2012
    look at the serial number if it is a RTA-8T the serial number is 8T-XXXXXX, is an RTA-11T then it is 11T-XXXXXX
    Radio Station W7ITC
  • civilian
    civilian Posts: 357
    edited April 2012
    I'd guess that is a pic from a seller and all the OP has. Not that that changes anything.
    ________________
    2 Channel-Denon AVR-4520/SDA 2.3TL's
    5.1-Denon AVR-4500h/RT3000P's/CS1000P/RT2000P's/
  • Dr.Stache
    Dr.Stache Posts: 4
    edited April 2012
    look liek some type of RTA.
    nooshinjohn Posts: 25,464
    edited April 2012
    They look like they have been stored in a humidor. look at the way the tops of the cabinets appear to be warping at the back.
    Might be just the vinyl laminate peeling.
  • boston1450
    boston1450 Posts: 7,674
    edited April 2012
    look like my rta 15 TL's. if there is 4 driver with tweeter in middle. and passive radiator on bottom and back
  • boston1450
    edited April 2012
    take the covers off. that might help. as others have stated also. good luck
  • transmaster
    edited April 2012
    They look like they have been stored in a humidor. look at the way the tops of the cabinets appear to be warping at the back. Might be just the vinyl laminate peeling.
    I see what you mean, the top of the left hand tower has been wet. if you look close the particle board has swollen. Once this sort of particle board does this you will have to carefully remove and replace the top board to repair it The veneer looks to be vinyl which you can purchase online and I have seen some of it that you can actually install using an iron. Unless you can get a fantastic deal on these speakers I would be temped to walk away.
    Radio Station W7ITC
  • Crashdot
    Crashdot Posts: 182
    edited April 2012
    Hi,
    I don't have the speakers - they are for sale on Craigslist. I was just curious as to the models so I could look up reviews or threads. I already have an excessive number of vintage Polk speakers, so I'm not in a giant hurry to get more unless these were something very special.
    Thanks everyone!
  • boston1450
    edited April 2012
    offer 50.00 and that would be worth loading em up. if all other parts are in working order. but it can be a project im sure
  • boston1450
    edited April 2012
    i think agfrost hit it on the money. misread model numbers. we had some posted on CL maine for 175.00 and they were still there 3+ weeks later. not sure why. maybe condition???
