In Walls
Post edited by VR3 on
What are you putting in the holes ?
They are Definitive inwalls, 6.5" with a 1" tweeter- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Are you going to paint them the same as the walls? Of course, if you're going to paint the walls white it's a none issue...Remember, when you're running from something, you're running to something...-me
I'd experiment with only the bottom center playing."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Looks like enough room to stick a fortress modded xover in thereMy System Showcase!
Media Room
Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
Living-room
Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
Headphones
Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun -
I actually like having the in walls non-painted... on the other hand I completely dislike painted inwalls as the color is never 100%
I am curious to see how the high/low center works out with the in walls, not having that angle anymore may create issues...
It is only sheetrock, can always patch holes and so forth!
Trust me, the second I unboxed them I thought... I could totally modify these!! Hahahhaha- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
OK - Definitive in walls are pretty freaking bad ****...
I am planning on gutting my den and starting over and this was kind of a test... great experience so far, still no mains - just listening to the centers, loved it... vocals lined up right at the center of the TV - loved it, absolutely loved it!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
