Marantz MA-500 Monoblocks X2 with bluejean cables
flyfisher
flyfisher Posts: 220
Figured I don't need this right now since my SC-05 can handle what I am currently running and use the funds for a TV.
I am the second owner and comes from a smoke and pet free home.I will throw in a pair of 6.5ft blue jean coax digital cable(Belden 1694A) that were used for interconnects.Also included are the user guides.
On one of the mono blocks,the green LED is out,but everything else is fine.
Asking $225 plus shipping.I need to find a box first and get a total weight for quotes.Will have it done this weekend.Local pick up is fine and I am close to Sacramento and the Bay Area.
These can be bridged to 360Watts @ 8ohms.
Here are the specs:
MA-500
Amplifier Section
Continuous power output (RMS)
8ohms 20 Hz - 20 kHz <.05% THD 125 W
4ohms 20 Hz - 20 kHz <.09% THD 180 W
EIA Dynamic power
8ohms 170 W
4ohms 270 W
2ohms 320 W
Bridged mode (2 x MA-500)
8ohms 20 Hz - 20 kHz <.1% THD 360 W
EIA Dynamic power
8ohms 500 W
4ohms 600 W
Damping factor at 8ohms 200
Frequency response 1 W 10 Hz - 100 kHz ? 1 dB
S/N ratio 116 dB
Input sensitivity/impedance 1 V/30 k?
General
Power requirements 120 V, 60 Hz, 230 W
Dimensions W/H/D 35⁄16? x 51⁄2? x 173⁄4?
84mm x 140mm x 451mm
Weight 14 lbs. 6.4 kg.
Living Room Monitor 60's*CS2*FXi A6's*VSX 21txh*BD-P1590
Spare Room RTi A7*CSi A6*FXi A4's*Epik Legend*BDP-05fd*DVL-919 Laserdisc/DVD player
Post edited by flyfisher on
