Sub Volume vs Output Level
ddank
ddank Posts: 28
Here's a curious question that maybe someone can answer.
Here's the setup.
The volume level on the sub which has it's own volume control is set at 30. The output level for the sub in the receiver is set at 0db.
Example 1.
I raise the volume control on the sub to 34 (approx. 2db) and leave the output level in the receiver at 0db.
Example 2.
I leave the volume control on the sub at 30 and raise the output level in the receiver to 2db.
Here's the question:
Will doing either of the adjustments above give me the same result? In other words, will the sound be the same no matter witch adjustment I choose to make or is it better to do it one way over the other. ie: is it better to raise the volume on the sub or the output level in the receiver.
Thanks for your help.
Post edited by ddank on
  • bobsauto49
    bobsauto49 Posts: 973
    edited April 2012
    Just received an E-mail from SVS that said i was to try and keep the sub at one level,and adjust it thruogh the avr! He said if i adjust the sub,i SHOULD re-run Audyssey! Hope this helps! Good Day,Rob
    "Everything I ever did in my life worthwhile I caught hell for"
  • steveinaz
    steveinaz Posts: 19,545
    edited April 2012
    Yep, let the AVR manage it.
    Bob--when is the SVS coming?
  • bobsauto49
    edited April 2012
    Fed-Ex Tracks it to me tomoro! And I have a half day off,so if it doesnt show,I'll be madder then a midget with a yoyo!!:lol:
  • steveinaz
    edited April 2012
    Hoahhhhh!! Somebody will be rippin' floor boards up. You're about to find out why SVS customers are loyal.
  • ddank
    ddank Posts: 28
    edited April 2012
    bobsauto49 wrote: »
    Thanks for the reply Rob. It's just what I needed to have confidence in the adjustments I want to make.
  • ddank
    ddank Posts: 28
    edited April 2012
    steveinaz wrote: »
    Steve, thanks for the confirmation to Robs answer
  • bobsauto49
    edited April 2012
    No problem! Good luck!
  • SDA1C
    SDA1C Posts: 2,072
    edited April 2012
    OMFG!!!!!WAAAAAAAAAAA
    Too much **** to list....
  • rtart
    rtart Posts: 848
    edited May 2012
    Let the AVR manage your bass levels. Set the sub volume at no more than 1/3. I'd start with 1/4. SVS manuals are pretty good, and there is a huge amount of info on sub calibration at AVSForum.com.
    My 7.4.4 DIY 4k Home Theater:
    Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
    Polk LSiM 702s x 4 on the Ceiling Atmos speakers
    Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
    2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
    Denon X3700H Emotiva XPA11 Gen 3
    XBox One X 4k & BD and streaming
    Panasonic UB-420 4k player
    HD-A35 HD DVD
    Oppo BD-103D for hirez audio
    Technics SL-D2 TT, Grado Gold Cartridge
    JVC DLA-RS2100/NZ7 projector
    Silver Ticket 135" microperf AT screen
    Berkline 090 electric recliners with Aura Bass Shakers
