Capacitor Burn-In Question
MHAMBONE
MHAMBONE Posts: 51
edited April 2012 in Vintage Speakers
When Burning-in new caps, does the volume of the music make any difference? What I'm getting at is, if I was to leave the radio or other source on all night with the volume low, would the burn-in be the same as if the volume was at a normal listening level? Just curious if I could somehow speed up the burn-in cycle by leaving the unit on low volume when asleep or not home. Thanks for any insight....
Mike
Pioneer SC-05 Receiver
Polk SDA-2b
Polk RTA 11TL w/RDO-198's
Polk RT25i Satelite Speakers
Polk CS 400 Center Speaker
Polk PSW 350 Sub Woofer
Samsung 46" 1080p LCD TV
Post edited by MHAMBONE on
    F1nut Posts: 50,755
    edited April 2012
    Basically, yes.
  • transmaster
    transmaster Posts: 428
    edited April 2012
    How long does it take to burn in a set of XO cap's. I finished with the Warfedale W35's it is fun listening to the new woofers breaking in, The orignal XO caps where 1971 Hong Kong PCV cap's which I have told where crap from the get-go, and 40 years down the road they didn't improve any, I installed a set of Dayton's. The W35's sure do sound a whole lot better now.
    Radio Station W7ITC
  • MHAMBONE
    MHAMBONE Posts: 51
    edited April 2012
    How long does it take to burn in a set of XO cap's?
    From what I have read here, for my application (RTA11TL upgrade and SDA2BTL upgrade) 300-400 hours.
    Mike
    Polk SDA-2b
  • Joe08867
    Joe08867 Posts: 3,919
    edited April 2012
    Having done this several times,
    I heard a change instantly (A bit Harsh), then at 200hrs(sibliance calmed some) a more subtle change at 300hrs(Easier to listen to for extended periods) and by 400hrs they became super smooth. Actually the 400hr mark may be a bit high. All of a sudden I noticed they were smoother or should I say awesome to listen to for hours upon end. It wasn't like a light switch.
    I usually leave the speakers on at a low to medium volume for a few days to really start the process. Like 3 days or 72hrs. Although the times don't really vary at all.
  • transmaster
    edited April 2012
    I am really looking forward to the Monitor 10B's the parts for their XO's will be here by the end of the week.
    Radio Station W7ITC
  • transmaster
    edited April 2012
    The Sonicap Gen 1 arrived today, waiting for the Axon True Cap's and miller resistors. I hope they will be here Friday.:cool:
    Radio Station W7ITC
  • dpowell
    dpowell Posts: 3,068
    edited April 2012
    They'll change over time but a good couple hundred hours minimum.
    polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
