6.1 Surround?
myoung84
myoung84 Posts: 13
edited April 2012 in Speakers
So I finally decided on what I wanted to buy for my living room upgrade and all of it should be here today and tomorrow. However, I have a couple of questions. I went ahead and spent a little more on the receiver to get the 7.1 model, however, my living room set up makes it impossible to do 7.1 easily since everything is set up at an angle. My rear speakers are technically on the sides rather than behind the couch. I have a great place to put a single speaker about 5' behind the center of the couch. Would this be a worthwhile upgrade? I am thinking of buying a single Monitor30 for this setup.
Pioneer VSX-921
Polk Series II Monitor50 front
Polk Series II CS1 center
Polk Series II Monitor30 rear
Polk PSW-111 sub
Post edited by myoung84 on
  • Joe08867
    Joe08867 Posts: 3,919
    edited April 2012
    I have used a 6.1 setup for the last 7-8yrs. It is the only set up besides 5.1 that works and it makes a difference.
    6.1 is much better than 5.1 IMHO.
  • bansheesho
    bansheesho Posts: 227
    edited April 2012
    I will have an extra center channel speaker after I get my q600 .... I was thinking of using that to set up a 6.1 too. I really don't want to have to move the speaker mounts and wiring from the rear though.... Would it make any sense or any improvements to have the rear 3 speakers at roughly the same distance back, but the rear channels would be up closer to the ceiling and angled down and the center would be at ear heighth or slightly higher on a stand or table that is butted up to the railing...
    some pictures to get an idea... there has been some changes to the front including the placment of the reciever (off to the side) and the front speakers to kef q900. Also, the love seat has been pulled foward and the walkway is now behind the loveseat. (Also the funky ceiling paint was fixed and the wires hidden and the shelves returned to the bookcase.)
    Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub
  • rooftop59
    rooftop59 Posts: 8,121
    edited April 2012
    I just added a rear center and I do think that 6.1 makes a difference. Just fills everything in nicely. To the op, have you thought about in ceilings for your surrounds? That way u could go with 7.1. I really like my klipsch in ceilings, and vanns has Some open box pairs for real cheap.
    Game Room 5.1.4:
    Bedroom 2.1
  • myoung84
    myoung84 Posts: 13
    edited April 2012
    Ceiling mounts are not feasible either. It's a 2 story house and the only way I could access the ceiling to run wires would be to pull up carpet upstairs and start cutting holes in the floor.... Don't think the wife would go for that one. LOL. I think I'll just run with 6.1 and be happy.
  • jbooker82
    jbooker82 Posts: 1,627
    edited April 2012
    Most 7.1, are really a 6.1 with dual rear speakers. That is why they are supose to be placed close together in the center.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
    txcoastal1 Posts: 13,502
    edited April 2012
    jbooker82 wrote: »
    Not really
    Front and rear centers, 2-fronts and 2 surrounds= 6.1
  • jbooker82
    edited April 2012
    txcoastal1 wrote: »
    Not really
    With most 7.1 sound tracks the rear suround sound track is a mono track. Sound equally plays out of the rear speakers. That is why they are to be placed close together and in the center of the room. I wasn't really talking about the phisyical number of speakers.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
