New face!
lanchile
My new face for my diy integrated amp! 3M metal sandpaper works wonderfully with aluminum! all done by hand.
Make it simple...Make it better!
This is the circuitry for the LED's lights that I used. They are connected right after power switch.
value of resistor will affect the brightness of led'sMake it simple...Make it better! -
Looks very nice! Good job. Are you planning to clear coat it to keep it looking new?"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Good idea! Thanks. I will clean it very well with alcohol and then I will put two coats of polyurethane.drumminman wrote: »Looks very nice! Good job. Are you planning to clear coat it to keep it looking new?Make it simple...Make it better!
