Looking to fix up old turntable!
thetawave2
thetawave2 Posts: 268
edited April 2012 in Electronics
My mom recently got her old turntable back, a Pioneer PL-A450, from her brother who had been keeping it in storage. The first time we plugged it in, we couldn't get it to work, although we heard clicking noises from inside. After removing the platter, we found that the drive belt had disintegrated and was reduced to a black gunk sticking to the platter and inside surface of the turntable. It doesn't appear to have gotten into the motor or any electronics, but I was wondering about a good way to get rid of the residue. I'm hoping to be able to look up the proper belt size so I can replace it.
Are there any other things I should do to restore the turntable to good working condition? I'm not afraid of taking things apart a little and getting my hands dirty, though I don't have a soldering iron and I'm not very knowledgeable about electronics. The motor seems to be in good shape, but I suppose a little lube wouldn't hurt. Any other suggestions?
My Stereo: Tannoy D100s, Yaqin MC-100B, VPI Traveler, Dynavector 10x5 MC Phono Cartridge, heavily modified Yaqin MS-22B phono preamp, TEAC EQA-20 equalizer, Belkin PureAV PF30 Power Conditioner, Canare 4s11 speaker cables, Custom dust cover from DigitalDeckCovers
Post edited by thetawave2 on
  • skrol
    skrol Posts: 3,437
    edited April 2012
    Could try a little alcohol to get the belt residue off the metal parts. If that doesn't work then a little Goof Off. Just keep it away from plastics.
    Belt:
    http://www.lpgear.com/product/PLA450.html
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • thetawave2
    edited April 2012
    skrol wrote: »
    Belt:
    Yeah I figured scraping off the excess with something plastic and disposable and getting the rest with Goo Gone would do the trick.
    Thanks for the link for the belt!
  • gdb
    gdb Posts: 6,012
    edited April 2012
    There is a whole pantload of Pio TT info on AK including sources for belts etc.
  • Fongolio
    Fongolio Posts: 3,516
    edited April 2012
    Goo Gone is the way to go. It won't hurt plastics. Goof Off is solvent based and will melt plastics etc.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • skrol
    skrol Posts: 3,437
    edited April 2012
    Good to know.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • thetawave2
    edited April 2012
    Well it took a lot of scrapin' and scrubbin' with a plastic spoon, Goo Gone, and lots of paper towel, but I got most of it off. There's still some black residue that I can't seem to get rid of, but there isn't anything gunking up the platter anymore. Ordering a replacement belt now, thanks to skrol!
