GM pickup tailgate bolt
thejck
Anyone have a GM truck that they are parting out.
I am looking for a speciality bolt that bolts the suspender cables from the bed body to the tailgate.
I thought I could get this at a local hardware store but apparently there is a pivot area on the bolt below the head that the cable pivots on that makes it hard to match.
Post edited by thejck on
Dealer maybe your friend.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Salvage yard...
What year is the truck?"Everything I ever did in my life worthwhile I caught hell for"
Does your neighbor have the same model truck?If you can't hear a difference, don't waste your money.
National Parts Depot
Ebay....how many dozen do you want ?
i was not able to find it on ebay. its a 2004.. i have thought about strolling into a parking lot to find one but thought it might not be worth it.
not even sure what to look at to seach online. i am thinking about salvage yard. -
Chevy/GMC dealers will fix you up with the right part.
Ck out Motormite/Dorman part# 38642. Shoud be what you need.The Kit does both sides. Usually cost about $30 from a Carquest store,if you can find 1 around you. Good Day! Rob"Everything I ever did in my life worthwhile I caught hell for"
bobsauto49 wrote: »Ck out Motormite/Dorman part# 38642. Shoud be what you need.The Kit does both sides. Usually cost about $30 from a Carquest store,if you can find 1 around you. Good Day! Rob
those came up with the hinges for the tailgate -
Sorry,thought thats what u needed!"Everything I ever did in my life worthwhile I caught hell for"
Get rid of the truck.
ha. i know i should. its a waste. anyone want to buy a sweet truck?
bobsauto49 wrote: »Sorry,thought thats what u needed!
its the bolt that connects the suspension cable to the tailgate itself. -
Here, I think this is it... GM part # 11609938
Try this link... http://www.gmpartsgiant.com/parts/gm-bolt-scrw-11609938.html
Acctually, this may be it... http://www.ebay.com/itm/Brand-New-Tailgate-Tail-Gate-Striker-Bolt-11570162-/230609526804
First link is #10, second is 8, if its the slide on for the strap, its 8. Hope this helps.
Does it look like this? -
thanks for your help cody.
that is not it. the bolt i am missing is a regular hex head bolt that you would use a socket set on. the only differences is that right below the head is a sleeve almost the size of the head that keeps the bolt from goin in all the way. and the cable loop rotates on this sleeve -
disneyjoe7 wrote: »Dealer maybe your friend.Chevy/GMC dealers will fix you up with the right part.
+1. My Chevrolet is 1994, and I can still get many of the parts at a reasonable cost.
If you're not willing to try the dealer, have you tried parts.com? Search under BODY HARDWARE, then PICK UP BOX, and choose the appropriate diagram for your model to get the specific parts listing. I don't park my truck at home usually, or I'd go and see if my bolt is similar to what you have described.
http://www.parts.com/parts/2004/GMC/?siteid=2&searchText=Alea jacta est! -
Can we get a pic of the opposite bolt in use?
I pulled the bolt off to look at it then put it on since i needed to haul some recliners.
it looks kinda like this one
http://t3.gstatic.com/images?q=tbn:ANd9GcS416ekqOw0-eHuNapDbaGFe5BshBcavmpoODvgt5RzdqfsITc6781sDO-qXQ -
Swing by a near by a GM dealer. I'm sure they stock them, wont take but a few minutes.
Try a shoulder bolt, small piece of steel tubing, or a hollow dowel pin. Maybe find something at Lowe's, but it is probably metric.
Just FYI.....there was/is a GM recall concerning their pickup tailgate systems. You should call and see if your's is involved, might be a free fix/upgrade.
would i just call a dealer with the VIN to check to see if this is the case? anything to save 6 bucks
Worst case, what's so hard about going down to any GM dealership and buying one?
They can probably still order them. Might even have one in stock.
I get parts like that for older vehicles all the time.
I think you will have a lot more luck there than you probably will on the Polk Audio forum. -
I was gonna' go there but, decided not to. Nothin like overthinking and dragging out small stuff. Case in point.....check out the latest thread on the the debate that has no end, my friend !
just hoping someone would have one sitting around. I called a dealer and I need to go pick it up. It is 6 bucks.. what a scam
You've worried more than six bucks of worry over this thing already. Specialty part, $6? Sounds reasonable enough. Go pay Chevy and be done with it.Jay
