also found a heathkit Tube pre
faster100
I was flea marketing today and found this heathkit tub pre amp.. only works when hooked to a heathkit tube amp.. so no way of testing... has 3 tubes in it though.. just thought id share
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Post edited by faster100 on
Very cool. Can you install some female RCA outputs on that so you can use any amp?
Maurice -
It actually has all the Rca in and outs as a regular pre does, only singles as its Mono. the part that makes it work only with a heathkit amp is the way to power it up. it doesnt have a power supply, so it has a 5 or 6 prong plug that plugs into the amps to power this unit up,MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
this is from e-bay, but you get the point, here is a back viewMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
That's going to be tough. If I come across the matching amp I'll let you know. You could start restoring it while you're looking for the amp. Restoring old equipments is fun. Especially tubes because they're easier to work with.
Maurice -
Forgot to ask...Did you pop open the hood to see what tubes are in there? If you see Telefunken, Mullard, Amperex, Siemens (just to name a few), they are very pricey. Some Telefunkens go for hundreds of dollars per tube.
Maurice -
I will look and see what tubes it has, and get backMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
