LSiC Help
bencorn
bencorn Posts: 49
edited April 2012 in Speakers
I have a 5.1 lsi system with 9's, c, and f/x. I love the sound but the center just seems to be softer than the rest of the system and I have tried running it hot or increasing the treble and it doesn't seem to sound right. Any way to get a little more performance from the center through crossover mods? I've also considered running dual centers or I've also read about people running another 9 as the center. Any ideas or anyone tried different options and could offer some pros/cons of them?
Post edited by bencorn on
  • bencorn
    bencorn Posts: 49
    edited April 2012
    Additional note. Currently running off a pioneer elite receiver with no external amp......I know..... I'm going to get an amp at some point but just wondered if anything else I could do in the meantime.
    EndersShadow Posts: 17,596
    edited April 2012
    I would run the auto calibration if you havent already. If you have, I would start messing with it to see what you can do with regards to the crossovers.
    Also where it the center located, is it wall mounted, etc.
  • codyc1ark
    codyc1ark Posts: 2,532
    edited April 2012
    I've got mine wall mounted, they need to be at ear level. Get an amp on it ASAP, you'll be much happier. I've got a modded C, and I'm very happy with it, but, placement was key. Otherwise, ES also gives some solid advice above.
  • bencorn
    bencorn Posts: 49
    edited April 2012
    I've got it mounted below my screen which is probably about 12 inches below ear height on the second row and about dead on for the first row. Calibration was run but I don't think I've run it since I moved the couches so I'll try running it again. I played around with my settings a bit more tonight and I definitely think it's something I've got set on the receiver that is making it sound weird. I'll have to mess with it some more when the wife isn't around. She hates all the sounds audyssey makes when it's leveling things.
  • BlueFox
    BlueFox Posts: 15,251
    edited April 2012
    I set mine to large. Add a few db to the center output level.
    tonyb Posts: 33,011
    edited April 2012
    Just go into the menu and manually adjust the settings/speaker levels to your liking. The calibration doesn't always get it right anyway.
  • maximillian
    maximillian Posts: 2,144
    edited April 2012
    BlueFox wrote: »
    That's how I have mine with I think +1.0dB and it works great. Blends nicely with the LSi9 fronts.
  • Lietuvis91
    Lietuvis91 Posts: 908
    edited April 2012
    Hopefully your lsic is set to small and you are running it at 80hz or higher crossover. Especially because you don't have an external amp you have to take the unnecessary load off the speaker so that it can do a better job playing a smaller range of frequencies. Set the crossover at100hz or 120hz and see how that changes things.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • Lietuvis91
    edited April 2012
    I have found that it takes a lot of power for the center to sound clean and clear when set to large. Even for the cs2. And location matters too, but yours sounds to be in a pretty good spot.
  • bencorn
    bencorn Posts: 49
    edited April 2012
    I'm pretty sure it is set to small but I haven't messed with any of the frequency settings yet. I'll try that next. I want to get proper power on it at some point but my home theater budget has been cut off until the home remodel is done.
    pitdogg2 Posts: 25,688
    edited April 2012
    check connections for phase. My wife wanted to dust under my center once and when she moved it she pulled out speaker connections. When she stuck them back in she reversed phase. Until I ran my room correction and it came back with CC out of phase did she then say "Oh yea those thingies fell out one day".....
  • BlueFox
    edited April 2012
    bencorn wrote: »
    Then set it to large and see what happens. You have to try different settings to find out what works best. Generally, centers are for dialogue, and do not have explosions being sent to the center.
  • drumminman
    drumminman Posts: 3,396
    edited April 2012
    tonyb wrote: »
    That's my experience. When I ran the auto calibration on my AVR and used those settings I could almost never hear the surround or front L-R mains. I did a manual set up, and it's much better.
    Watching the Masters on Sunday at times my wife and I couldn't tell whether the birds chirping were from the cable feed or outside :cheesygrin:
  • bencorn
    bencorn Posts: 49
    edited April 2012
    Messed with the settings last night and decided to start over. So I did a full reset on the receiver to clear out all the settings, set all the speakers to small, set the speaker distance manually, and then left everything else alone. Vast improvement. Not sure if my room is weird or something but auto-cal seems to make it sound weird. I just set my rears to +2 and my center to +1 and now everything blends perfectly.
  • Lietuvis91
    edited April 2012
    I have never had any luck with auto calibration either. After auto cal my center is never loud enough and i can't hear the surrounds at all. So I also had to do it on my own. Glad you figured it out.
  • codyc1ark
    edited April 2012
    Lietuvis91 wrote: »
    I knw what your saying. I always auto cal then bust out the SPL meter, I feel like I can get it dialed in great with a little help from the meter.
  • bencorn
    bencorn Posts: 49
    edited April 2012
    Lietuvis91 wrote: »
    Thanks me too. Now I just gotta seal the amp plate on my subwoofer so it stops whistling on heavy bass in movies. Then start saving up for an amp to relieve my poor receiver.
