Audioengine A5 Powered Speakers
jwhitakr
I have for sale a very good condition used set of Audioengine A5 speakers. These are powered speakers that work with iPod, iTouch and any other products that charge via USB. The sound that these babies put out is really impressive for bookshelf size speakers. Would love to keep them, but they just don't get much use any more. The only issue with them is that the blue LED light does not work, so when you turn them on there is no light that indicates that they are powered on.
Included is the AC power cord, the RCA audio connector cable, speaker wire and a new upgraded 3.5mm cable to connect to a laptop or MP3 player.
Price is $180 + shipping. These speakers usually sell for $200-$250 plus shipping on eBay. I'm in Kansas City, KS area if anyone local is interested.
My HT
HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
AVR: Harman Kardon AVR 235
Video: 80GB PS3, Toshiba HD-XA1 HD DVD
Fronts: Polk Audio RTi8
Center: Polk Audio CSi3
Amp: Emotiva LPA-1
Surrounds: Polk Audio R150
Sub: HSU STF-3
The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
Amp: Emotiva LPA-1
Sub: HSU STF-3
Post edited by jwhitakr on
Here is additional info from the Audioengine website:
iPod power charging port (Combo Port)
2 audio inputs
Built-in power amplifier, no receiver/amp needed
Power outlet for Airport Express
Front panel volume control
Custom Kevlar woofers for super low end
Silk dome tweeters for smooth highs
Hand-built and tuned cabinets w/high-gloss furniture-grade finish
Magnetically shielded for placement near video monitors
Type: 2.0 bookshelf-style, powered speaker system
Power output: 45W RMS/ 70W peak per channel (AES)
Inputs: 2 X 1/8-inch stereo mini-jack
Outputs: USB Type A (power charging only)
Main voltages: 115/230V 50/60Hz manually switchable
Size (each): 10.0(H) x 7.0(W) x 7.75(D) inches
Weight: 6.4Kg/14lbs (left), 4Kg/9lbs (right)
Amplifier type: Dual Class AB monolithic
Signal-to-noise: >95dB (typical A-weighted)
THD: <0.05% at all power settings
Crosstalk: <50db
Frequency response: 50Hz-22kHz +/-1.5dB
Input impedance: 10K ohms unbalanced
Protection: Output current limiting, thermal over-temperature, power on/off transient protection, replaceable external main fuse
Materials and Construction:
1-inch thick MDF cabinet
5-inch Kevlar woofers with advanced voice coils
20mm silk dome tweeters with neodymium magnets
Torroidal power transformersMy HT
Amp: Emotiva LPA-1
Sub: HSU STF-3
The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd -
I love my A5s. GLWTS
pm sent
Thanks Rick88 and gdpeck - I will be sad to see these go but happy that a fellow Polkie will be getting them.
logo896 - PM coming your way.My HT
Amp: Emotiva LPA-1
Sub: HSU STF-3
Sold and shipped.My HT
Amp: Emotiva LPA-1
Sub: HSU STF-3
