Gonna go 7.1
Hello all,
Used to be agioino (can't believe it's been almost 10 years!) now gforce890.
Anyway.
I'm getting tired of missing total 7.1 trueHD from my movies because I'm only 6.1.
I want to upgrade but I'm trying to decide which way to go with expanding my rear center to two to get to 7.1.
I'm still using my RM-3000 for surrounds and I've still got my CS-175 in the rear.
Lots have changed; running Marantz AV7005 to the HCA-2205A and added Zamp v.3 sticking with the Parasound mindset/sound matching, etc.
So, should I buy another CS-175 or start over and go with something else (another pair) in the rear?
My concerns are that two CS-175 might be a little much for the room and space it's in and I'm also concerned with power requirements.
On a side note, I'm very happy with my Zamp v.3 if anybody is looking to expand or use in a small setting.
Thanks in advance for your replys.
Anyway.
Post edited by gforce890 on
Ok so nobody's biting. Let's put it this way are the omw5 a good match
with rm3000,sda2b and cs400??
