Ceiling panel that is remote controlled to show speaker.
Can anyone provide me with a ceiling lift product as to the title above? The speaker is only required to be exposed when in use via remote control. I have taken a look through lots of websites though cannot find any product to house a speaker of this size and weight. speaker is this one: http://www.communitypro.com/files/literature/spec%20sheets/IHP1296_SPEC.pdf
There is a concrete slab above the finished ceiling to attach the lift to, the ceiling surrounding the demountable panel (1100x620mm approx) will be standard 12.5mm plasterboard with plaster skim.
Spink.
Spink.
Post edited by Spink on
I'm pretty sure that is something that will have to be custom fabricated. I may be wrong, have been before.If you can't hear a difference, don't waste your money.
There is a company called Inca that makes lifts that can be hung to lower speakers from the ceiling.
Look up Concealed Speaker Lifting Systems. -
See, I'm wrong again!!!!! Here's a link to the Inca speaker lift page. Good call Joe.If you can't hear a difference, don't waste your money.
I am sure technology has come quite a ways as far as the remote goes. Many years ago, I used to build custom coaches. I installed many a hidden monitor in end tables for Prevost. The lift link provided in regards to INCA is really a snazzy way to go and they work well. Be sure you tell them you want it activated by a programmable remote or you will get an infrared remote the size of a loaf of bread. Also with that shape of speaker I would look at tilt instead of vertical lift. Just my .02. Good luck, cool idea!Too much **** to list....
