csi20 center channel speaker
badboy916
i just purchased the csi20 center channel. it came with rubber feet which i can stick on the bottom of the speaker. the speaker is being placed on a shelf above my tv. should i use the rubber feet or would it be better to leave them off? does it matter sonically?
thanks for your help
brian
brian
I'd put them on so you don't scratch the bottom of the speaker. Other than that, I can't see how would make a difference.Receiver = Denon AVR-3803
DVD = Denon DV-2900
Fronts = SDA SRS 2.3TL's
(Carver m1.5t)
Center = CSi40
Side surrounds = Fxi30's
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Pioneer SX-1050 receiver
Rti38's
