My new walnut SDA 1C end caps!
gwg_97
gwg_97 Posts: 332
edited April 2012 in Vintage Speakers
Hi all,
I just thought I'd post a few photos of my new walnut end caps:cheesygrin:. It was a lot of work but I am very happy with the results. Its walnut veneer over MDF with an oil/varnish finish (with a fair amount of sanding). I also spent a lot of time trying to get the veneer seam as tight as possible (see the close up photo). End caps seem to be all the rage these days and I'd thought I would join the fun. Crossovers are next!
System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded
Post edited by gwg_97 on
  • chumlie
    chumlie Posts: 8,658
    edited April 2012
  • michaeljhsda2
    michaeljhsda2 Posts: 2,186
    edited April 2012
    Very nice!
    SDA SRS 2.3TL's
    SDA 2B TL's
  • gwg_97
    gwg_97 Posts: 332
    edited April 2012
    Thanks guys. It was a lot of fun and it kept me busy for a few rainy weekends.
  • geoff727
    geoff727 Posts: 546
    edited April 2012
    gwg_97 wrote: »
    .....it kept me busy for a few rainy weekends.
    A rainy weekend here in Seattle? Say it isn't so!
    Those look very nice. I like the richness of walnut.
    G~
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS-II (modded)
    Infinity RS-IIIa (modded)
    Infinity RS 2.5 x 2
    Magnepan 1.6QR (modded)
    System: http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1290711373
  • chumlie
    edited April 2012
    I know you get plenty of them ( rainy weekends ). My Mother lives in Eugene, Or. **** about the rain daily but it beats the snow. I tell her thats what she gets for living in a rain forrest. Beautiful out there in the summer.
  • FTGV
    FTGV Posts: 3,649
    edited April 2012
  • gwg_97
    gwg_97 Posts: 332
    edited April 2012
    geoff727 wrote: »
    G~
    Hey Geoff,
    I've seen a lot of your very nice projects. I'm sure you can relate! January, February and March are rough and it helps to keep busy.
  • gwg_97
    gwg_97 Posts: 332
    edited April 2012
    chumlie wrote: »
    Chumlie,
    I was just in Ohio last week for work. All I can say is that you guys are at least 3 weeks ahead of us. It was beautiful and 80 degrees in SW Ohio last Wednesday.
  • chumlie
    edited April 2012
    gwg_97 wrote: »
    Chumlie,
    Trust me. Thats not the norm. Last year we had 2ft of snow. But it was a nice change. 45 and rain now.
  • Fongolio
    Fongolio Posts: 3,516
    edited April 2012
    Very nice.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • gwg_97
    gwg_97 Posts: 332
    edited April 2012
    Lasareath wrote: »
    Very Nice!
    Are those just for the bottom or do you have them on top as well?
    I have them for both the top and bottom. Only so much room in the photo. I just set the spikes on them because I thought they looked cool against the wood.
  • gwg_97
    gwg_97 Posts: 332
    edited April 2012
    Lasareath wrote: »
    Did you make those end caps?
    Yep, it was a labor of love.
  • gwg_97
    gwg_97 Posts: 332
    edited April 2012
    That was so much fun that I'm thinking about making another set in rosewood. Any other suggestioons?
    Also, what have people used for glue to allow fairly easy removal if I want to change things up in the future?
  • geoff727
    geoff727 Posts: 546
    edited April 2012
    gwg_97 wrote: »
    I would recommend using 4 through-bolts on them , like the larger SDA's. You'll have to drill 4 holes in the tops and bottoms of the enclosures, but it's so much stronger and easier to take apart if need be.
    Have you thought about doing side rails for them, for a miniature SDA SRS /SRS 2 look?
    G~
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS 2.5 x 2
  • falconcry72
    falconcry72 Posts: 3,580
    edited April 2012
    Very nice! I'm jealous!
  • gwg_97
    gwg_97 Posts: 332
    edited April 2012
    Hey Geoff,
    Yeah, I was thinking about side rails; however, the grill cloth is in such excellent shape that I hate to mess with it. I do think it would look very nice. We'll see. Also, thanks for the through bolt tip.
