A + B Speakers = Stereo?
JoeLansing
JoeLansing Posts: 6
edited April 2012 in 2 Channel Audio
Dumb question of the night. I've got an Onkyo HT-R520 http:\\www.lotsoffun.org\share\onkyo520.jpg This is the manual for it. http://lotsoffun.org/share/onkyo520.pdf .... I have 4 Monitor 40 speakers. Do I just connect to the Front *A* and Front *B* speakers R/L to get 4 channel stereo or is there a better way? I've got a 38' x 16' room. Bar, Pool Table, seating. No theater crap. I just want it to rock. I'm trying to start with a Monitor 40 in each corner, then add BIC F12 or something. Maybe 2 Dayton 12's. I love the 4 monitor 40's for $65 each. The Onkyo 520 still has a sticker on the front that says 1,000W but that's with the sub it came with. It does pull 6.5A from the wall so it's not wimpy. I want it to rock good stereo.
- Joe
Post edited by JoeLansing on
  • JoeLansing
    JoeLansing Posts: 6
    edited April 2012
    Smallies wrote: »
    So what does that have to do with A and B fronts?!?!?!
    - Joe
    edited April 2012
    Yes, A and B for 4 channel stereo. I might add that the room is fairly large for monitor 40's and that receiver is pretty much entry level so just be careful trying to crank it up too loud.
    F1nut Posts: 52,009
    edited April 2012
    JoeLansing wrote: »
    - Joe
    He hasn't been taking his meds.
  • PolkClyde
    PolkClyde Posts: 662
    edited April 2012
    f1nut wrote: »
    he hasn't been taking his meds.
    ouch!
    PolkAudioClyde
  • olilugo
    olilugo Posts: 405
    edited April 2012
    I looked at the picture. the A channel connections are for your maim front stereo speaker.
    The B channel were ment for providing stereo to a second room. if you make A+B active that means you should be able to listen the same music in the two different room say room A and room B in he house. if you enable only room A or room B then sound will only be in whatever room you enabled.
    keep in mind that B channel is ussually a lower power rating than the A channel.
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    Sub: Velodyne DLS-3750R
    Receiver: Pioneer SC-07
    Amplifier: Sunfire TGA5200
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
    CDP: Pioneer DV-48AV
    Interconnect cables: SignalCable analog II
    speaker cables: SignalCable Ultra Speaker Cables Bi-wire
  • malvrich
    malvrich Posts: 49
    edited April 2012
    my onkyo is similar and the Bs are indeed meant for zone 2.
    i suggest connect all 4 sp. then set speaker config to reflect left, right, surr. left, surr right, sub(?) and no center.
    then run the receiver in "all channels stereo" mode.
    this will still have all 4 in A and bypass B.
    from what i gather this will prob get you the most efficient performance
