SACD Player
deronb1
My SACD player wont put out any sound in 2 ch with an SACD. Reg CDs work fine in 2 ch and I can get sound in multi channel 5.1 mode with an SACD, but nothing in 2 ch. I have checked all the settings, and still nothing. Opt output. Weird. Any suggestions?
Post edited by deronb1 on
Did it use to work in 2 channel?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I think you have to use the analog outputs for SACD....not optical (digital). In 5.1 you're probably hearing a downmix PCM version.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Ok guys, thanks. It only has opt dig out and then the analog 5.1 output. Have the RCA jacks input into my multi channel in on my Pio, so I have to set the AVR to "Multi-Channel In". No biggie really, just wanted to hear the SACD in two channel stereo.
BTW...you can use any 2ch input on the recv'r....doesn't have to be "Multi-Channel In"
Ah! That makes sense. The AVR doesn't know any better. Now I feel dumb. Thanks for the insight :redface:
