Marantz 5005 Belkin PF60 Trigger
NE1410S
What I am looking to do is turn on my Carver amp via the trigger sent out from the Marantz 5005 to the Belkin PF60. Is this possible? If so, what type of cable is needed? I've looked at the manuals multiple times and it's just not sinking in. Thanks for your time
Post edited by NE1410S on
Not to sound like a dink but since your Marantz has a 12 volt trigger (it does doesn't it?) why not just hook that up from your receiver to your amp? With my receiver there is a setting which will ask you yes/no on using the trigger. Then everytime you turn your receiver on the amp will turn on as well. Same with power off.
Welcome to Club Polk btw!Remember, when you're running from something, you're running to something...-me -
Are you saying this can be done through the pre-outs? That is the only connection from the amp (Carver TFM-45) to the receiver.
Oh yes, I gotcha now. An older Carver amp, oops, sorry for my mistake, I'm the dink!
I'm not that familiar with the BelkinPF60, I have the APC H15. There are some here who do own them so hopefully someone will chime in for you on this!Remember, when you're running from something, you're running to something...-me -
Nope, no dinks here... I think the Belkin outlet the receiver is plugged into needs to be un-swithched. When you turn the receiver on w/the remote, the receiver would trigger the Belkin to turn on and feed the Carver power on a time delayed switch. I'm not certain the Belkin, or the Marantz is designed to do this.
Run the trigger from your Marantz to the trigger in on the Belkin using a monaural headphone cable. Plug the Marantz into the AVR plug of Bank 5. Plug the Carver into the amp plug for bank 6. Set the bank 6 switch to SWITCHED and DELAYED. Set the delay switch to 5 seconds. Press the remote button on the front of the unit so that is set to on. Voila! When you turn the Marantz on, the Belkin will kick the amp on.
If you get a thump when the Carver powers on, try adjusting the delay switch on the back to 10 or 15 seconds.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
I have a new PF60....and I am thinking about the same thing. Only problem is.. I think both my Carver's have an internal "slow start" circuit, which means if you put a delay on the bank, then the receiver will almost certainly be cycled up and ready to rock by the time the amps kick in...producing the "thump". I'm wondering if it might not be best to put the amps on instant on switch and then....maybe...they might kick in around the same time."Making life enjoyable through expensive electronics." BillD
Pioneer Elite SC-57
M70 series 2 mains
CS2 center
M40 surround
M30 front height
SVS PB 12 NSD
Carver TFM-45 (mains)
Carver A753x (center, surround)
320GB PS3, 42" Panasonic G10,
M60's as a Zone 2 off of the Pioneer in the living room
R.I.P. Onkyo TX-NR807 -
Voila is right, thank you kind sir. I even had the proper cable available.
One way to find out! All it takes is a flip of a switch to try it. Sadly, my Adcom thumps no matter how I do it, but it's not loud enough to concern me. Of course, I'm having to trigger off my cable box's switched outlet because my AVR doesn't have a trigger out.ibewbrother wrote: »I have a new PF60....and I am thinking about the same thing. Only problem is.. I think both my Carver's have an internal "slow start" circuit, which means if you put a delay on the bank, then the receiver will almost certainly be cycled up and ready to rock by the time the amps kick in...producing the "thump". I'm wondering if it might not be best to put the amps on instant on switch and then....maybe...they might kick in around the same time.Equipment list:
Emotiva XPA-3 amp
Glad someone on here was able to help you out. Good people here!Remember, when you're running from something, you're running to something...-me
