Differences between the CSI A6 and CSI 40?
edited March 2012 in Speakers
Hi to all. As I pointed out in a prevous thread, I am replacing my front mains from the RTI 70 to either the A7 or A9. Should I also replace my CSI 40 with the CSI A6? Is there enough improvement to warrant the replacement to match the new mains, or will the CSI 40 integrate seamlessly with the new A7 or A9?
Post edited by brasil on
Welcome!
    edited March 2012
    I'm using A7's in my HT rig with a CSi40 and I can say it's totally seamless. Save your money.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
    edited March 2012
    another option is sell your current center, then get a csi5 for like 225 on ebay from Polk. csi5 is like csia6 in different box; same drivers and crossover
    edited March 2012
    So the driver's and crossovers are different from the CSI40 to the CSI A6? I know that the box and such is all new.
    edited March 2012
    yes, way different. they don't share anything.
    edited March 2012
    Don't change it out until you have listened to it with your new speakers. You might not be able to detect a difference, thereby saving some money. You can always change it out later.
    edited March 2012
    Decided to get the A6 for a perfect match to the A9's. Thanks for the input.
    edited March 2012
    Best way to go!
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
Welcome!
Welcome!
