Power wire for 1900 watts.
Zeik75
Zeik75 Posts: 2
edited March 2012 in Car Audio & Electronics
Hi i am in the process of building a system for my car and im going to end up with 5 polk amps. The combined wattage that they will draw at the right Ohm's 1900 watts. I currently have a db link 4 gauge power wire that is supposedly rated at 2000 watts. I wasn't sure if the numbers are too close to call it safe or if i should up to a 0/1 power wire. Any help on this would be greatly appreciated.
Post edited by Zeik75 on
  • pentoncm
    pentoncm Posts: 379
    edited March 2012
    Are we talking RMS wattage here? If you really have 1900 RMS then I would recommend running a single 0/1 guage wire back to a distribution block and then from there use 4 guage to the amps.
    Audison Bit Ten
    Kenwood X595
    Polk MM6501
    Polk MM1240
    Mtx 704x
    Alpine MRX50
  • KaosTsoc
    KaosTsoc Posts: 372
    edited March 2012
    I agree with pentoncm on running the 0/1 gauge from batter to a distro block. Be sure to put a fuse no more than 18 inches away from the battery. I would run 4 gauge for power, and ground for all the amps that will run your door speakers, and tweets. I would then run a 0/1 gauge for power, and ground for the amps that will push your subs. What amps do you have?
    Thanks.
    2006 Prerunner Access Cab
    5 Speed 4 cycl 2wd
    Audio:
    Pioneer P860 Head Unit
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
    Kinetik HC2000 battery and Sleeve
    200 Amp Mean Green High Output Alternator
    Need a DJ, photobooth, or both for rent?
    http://photoboothdallas.org
  • eloplayspolo
    eloplayspolo Posts: 1,117
    edited March 2012
    https://www.knukonceptz.com/assets/pdf/PowerWireSpec.pdf
    Take a look at that page. Has everything you need to know.
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • Zeik75
    Zeik75 Posts: 2
    edited March 2012
    i have two of the PA880 for my subs that i am running at 2 ohms so they are rated 500rms each. then i have a PA330 that is which i will try and wire it down to a two ohm load so it will push 150 total for both channels. one PAD2000.2 which is 250 rms for both channels at 4 ohms. and finally i have the PAD4000.4 which pushes 500rms for the 4 lines combined at 4 ohms. i currently have a 4 gauge power fused at the battery and ran to one PA880 for a sub. this is still a work in progress and i don't actually have all the amps yet but this is what i plan to get because they match up with my speakers well and they all have a low footprint so it works out well with trunk space. the rca's and remote turn on are fine its just the power thing thats bothering me. id rather be safe than sorry with all this money.
