watts,db,spl???
littlewoodboats
littlewoodboats Posts: 823
edited March 2012 in 2 Channel Audio
How does all of this work?
I am asking as I just got back into stereo and in all honesty I did not know much about it to begin with.
I recently picked up a pair of SDA 2A rated at 92db 1watt one meter
How does the db/spl change with amplifier power?
Post edited by littlewoodboats on
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2012
    for every 3db increase you need twice the wattage.
    RT1
  • zingo
    zingo Posts: 11,258
    edited March 2012
    Get a pair of Klipsch speakers and FEEL the SPLs...
  • zingo
    zingo Posts: 11,258
    edited March 2012
    Sound Pressure Level and Power
    ``Threshold of audibility'' or the minimum pressure fluctuation detected by the ear is less than of atmospheric pressure or about N/m at 1000 Hz.
    ``Threshold of pain'' corresponds to a pressure times greater, but still less than 1/1000 of atmospheric pressure.
    Because of the wide range, sound pressure measurements are made on a logarithmic scale (decibel scale).
    Sound Pressure Level (SPL) , where N/m.
    SPL is proportional to the average squared amplitude.
    Sound Power
    Total sound power emitted by a source in all directions.
    Measured in watts (joules / second).
    Sound Power Level (PWL) = , where watts.
    Sound Intensity
    Rate of energy flow across a unit area.
    Sound Intensity Level (IL) = , where watts/meter.
    Multiple Sources
    Two equal sources produce a 3 dB increase in sound power level.
    Two equal sources produce a 3 dB increase in sound pressure level, assuming no interference.
    Two 80 dB sources add to produce an 83 dB SPL.
  • pearsall001
    pearsall001 Posts: 5,237
    edited March 2012
    Here's a great site that will help you understand SPL requirements & a host of other information all audio & video related.
    http://myhometheater.homestead.com/splcalculator.html
  • Joe08867
    Joe08867 Posts: 3,919
    edited March 2012
    The SPL you are speaking about with those specs is sensitivity more than output. I have had my SDA2's well past 100db before.
    The sensitivity is how much sound they can output at 1 watt from 1 meter away.
    For smaller amps and flea watt tube amps the higher this sensitivity the better (Usually) that is why Klipsch has such a strong tube following. There speakers are very effecient. This doesn't always translate into better sound though. I have seen very inefficient speakers that sound just awesome but need more power to get that awesomeness out of them. Polk Lsi9's come to mind.
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2012
    With 92dB rated speakers, at:
    2watts...95dB would be output
    4watts...98dB
    8watts...101dB
    16watts...104dB
    32watts...107dB...and so on.
    Notice how quickly power gets gobbled up at higher outputs.
  • littlewoodboats
    edited March 2012
    Thanks for the replies and information.
    With the listed impedance my stuck in Class A Yamaha should be making 19 watts. Sounds great but one can definitely hear it start to run out of gas. I have a stereo tube amp in the works but that is still in the bottom half of the recommended power listings on the speakers.
    Based on what has been posted here I should have no issues with a lack of power. I am a bit more responsible with the volume control than in my younger days but it is nice to be able to turn it up a bit should the urge hit me.
  • steveinaz
    edited March 2012
    92dB is pretty efficient, I think you'll be fine.
    tonyb Posts: 33,066
    edited March 2012
    Don't put so much emphasis on watts, it's current speakers love. Also, with all the numbers thrown out at you, keep in mind those are for 1 meter away. Your room size will have alot to do with it too along with placement. A tube amp should do well on SDA's, but also consider rolling a few to get the sound you like.
    edited March 2012
    Tony is right. I have all of 50 watts a side (tubes) on my SDA 2Bs and I can't turn the amp past 12:00. Too loud.
    Of course the darn thing weighs about 50 lbs. And most of that is transformers, etc.
    cnh
