Clarion DUZ385SAT
KaosTsoc
Hi guys. I need some tech help here. I am trying to figure out why the above head unit is going into amp protect mode? There are no external amps hooked up the HU, so that crosses that one out. I did manage to look at all the wire connections, and whoever did this used shrink rap around the exposed wires, and they all seem to be hooked up correctly. They also had an amp hooked up at one point, cause the wires are still ran, and were connected in the back of the HU. So, I unplugged these to cross that off as well. I did not do a detailed analysis of the wiring as of yet, but that is my next step. I was wondering if I might be able to pick someones brain to see if anyone has any other suggestions that I can use, and look at.
Thanks.
Thanks.
2006 Prerunner Access Cab
5 Speed 4 cycl 2wd
Audio:
Pioneer P860 Head Unit
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
Kinetik HC2000 battery and Sleeve
200 Amp Mean Green High Output Alternator
Need a DJ, photobooth, or both for rent?
http://photoboothdallas.org
5 Speed 4 cycl 2wd
Audio:
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
Post edited by KaosTsoc on
I'm not a techie by any stretch of immagination, but if it goes into protect mode with the rca's disconnected, maybe the amp inside the hu is the problem?
I re read what I put, and left out something. When I had the HU pulled out, I completely disconnected the HU. When I plugged it back in the radio worked like it should. I let it play for 10 min each both with the ACC on the car turned on, and also with the engine running, and had no issues. Once I left the guy that I am doing this for called me like two hours later, and told me it had gone back into amp protect. I do agree with arun that it very well might the internal amp on the HU. So, this open up the question of could it be the fuse that is on the harness? The HU does not have the fuse on it below the pin hook up area (if that makes sense). I will try to see if I can post of pic of the harness so you can see. I think there are two of them on the acutal harness.
I know this goes to another forum, but if you scroll down to the 5th pic you will see the harness:
http://www.google.com/imgres?imgurl=http://i755.photobucket.com/albums/xx192/AzNFoLife924/DSC00815.jpg&imgrefurl=http://www.subaruforester.org/vbulletin/f65/aftermarket-clarion-double-din-unit-sale-74114/&usg=__eclU-ei6yozYm_VAL9vtuQVG0dg=&h=768&w=1024&sz=142&hl=en&start=29&zoom=1&tbnid=lEPqR4i2me1uXM:&tbnh=113&tbnw=150&ei=zsBwT5bXFKfPiALr8dzJBQ&prev=/search%3Fq%3DDUZ385sat%2Bwiring%2Bharness%26start%3D21%26um%3D1%26hl%3Den%26sa%3DN%26rls%3Dcom.microsoft:en-US%26tbm%3Disch&um=1&itbs=1
Thanks.2006 Prerunner Access Cab
5 Speed 4 cycl 2wd
Audio:
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
http://photoboothdallas.org -
If it is the amp on the HU. Does anyone think it could be salvaged, and or fixed? And what could cause the HU amp to do this anyway?
5 Speed 4 cycl 2wd
Audio:
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
