Difference between 6500 & 6502 drivers
steve rogers 19
2012-03-25. Hi all, I need a MW6502 driver. I was told ir can't be fixed with super glue. I found someone who has a 6500 driver for $20.00. Do they sound signifigantly different? I read that the spec are very different and it was stated that they could not sound alike. But I cant seem to find that post again. Can someone point me in the right direction to get a good used 6502?
Thanks Steve.
Thanks Steve.
Post edited by steve rogers 19 on
The specs for the MW6502 are...
Q - 1.970
Resistance - 3.520 Ohms
Fs - 44Hz
I've never seen the specs for the MW6500.Political Correctness'.........defined
President of Club Polk -
I don't recommend mixing the two and the crossover is specifically designed for that particular driver. You can see from the specs below that, in spite of looking nearly identical, they are quite different. The 6500 and the 6502 both show up fairly frequently here and on ebay.
Stan
Driver: MW 6500 Driver's model #.
Brand: Polk Driver's brand name.
Fs: 31.0000 Hz (Free air resonance)
Vas: 2.6486 ft^3 (Compliance volume)
Qts: 0.2190 Total Q
Qms: 1.3000 Mechanical Q
Qes: 0.2640 Electrical Q
Sd: 0.0130 M^2 (Piston area)
Xmax: 3.1800 mm (Cone excursion, linear)
Revc: 6.5000 ohms (DC resistance)
Znom: 8.0000 ohms (Nominal impedance)
Pmax: 35.0000 watts maximum rated power
Driver: MW 6502 Driver's model #.
Fs: 44.0000 Hz (Free air resonance)
Vas: 1.2360 ft^3 (Compliance volume)
Qts: 0.2790 Total Q
Qms: 1.9700 Mechanical Q
Qes: 0.3250 Electrical Q
Revc: 3.5200 ohms (DC resistance)
Znom: 4.0000 ohms (Nominal impedance)
Pmax: 35.0000 watts maximum rated powerStan
Main 2ch:
HT:
Other stuff:
