HELP Newbee needs direction
steve rogers 19
2012-03-25. Man I'm a bad typist! Here is my set of questions corrected. Hi all, Polk monitor series 5 23375 info from rear tag. What do I have here???? Worth fixing???? One driver "woofer" has come apart where the coil cone and centering bellows are all attached, noticed scratchy sound so I stopped using both immediately. The other unit works good & sounds good.
Can I super glue it all back in place? Where can I get a replacement speaker??? From Polk? From someone from this forum? Any phone num for them & a contact name? And finally what upgrades are necessary or just optional for the crossover? Xover components all look good but I did not get a schematic & meter them. It seems that my only problem is the disattachment of the one driver "woofer?" cone from the center tube and the centering bellows. Thanks Steve.
Post edited by steve rogers 19 on
I bet you have been called a SPAMMER before.
Not the OP, but douchus Rickchen89.Lumin X1 file player, Westminster Labs interconnect cable
