Marantz PM-5004 Integrated Amp
skrol
skrol Posts: 3,476
edited March 2012 in 2 Channel Audio
Anyone have any experience with this amp? Stereophile had a very favorable review of its younger sister PM-5003 and a follow-up comparison with the 5004.
I actually bought the amp for a very good price and have 30 days to decide if I want to keep it. It would be replacing my Denon DRA-835R from 1991. I am skeptical as it is pretty light weight compared to the Denon and has a much more modest power rating. It is rated 35W into 8 ohms, 45W into 4 ohms. Would this amp be sufficient to drive a pair of LSi9 (that I hope to get in the future)?
Stan
Stan
Main 2ch:
HT:
Other stuff:
Post edited by skrol on
    edited March 2012
    That Denon receiver is pretty beefy (5.7 amp draw or 684 watts?) Marantz draws only 110 watts? That's quite a difference even if we take into consideration a more efficient design, it still looks overpowering in comparison.
    To properly power LSI-9s with an integrated I'd be thinking something like a NAD C37X series 150 watts x 2 / 8 ohms, 33.6 lbs. Great headroom. Or a Cambridge Audio Azur 840A (similar class integrated).
    Unfortunately this probably triples or quadruples the budget. And it seems that what your looking for is something well under a grand.
    I'm not even sure my NAD C325 at 50 watts x 2 could handle LSi-9s. It just about does the job with my LSi-7s and I suspect that the Marantz above would also sound pretty good with 7s. But the impedance curves on the 9s are troublesome for lower powered amps.
    I haven't heard any of the Marantz integrateds above. But I have heard their AVRs on well respected speakers while I was in China, may times. And I almost always "liked" what I heard. I've heard LSi-7s, B&Ws, Dalis, and some Focals on the AVRs. So I suspect the integrateds must sound at least as good and probably that much "better".
    If I were going with a PM-5004, I definitely scale down to the LSi-7s. Otherwise up the amp budget for the 9s.
    cnh
  • skrol
    skrol Posts: 3,476
    edited March 2012
    My Denon has been serving me well and drive the RTA11TL very nicely. My wife gets on me to get rid of my big speakers and I figure the LSi9 would be a good way to go. Every one says separates are the way to go for the LSi9.
    My listening area is fairly large 18" x 32" but I don't usually play loud. It sounds like this Marantz is not the amp for me but I'll probably play around with it while I still have it.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,476
    edited March 2012
    After listening to the 5004 last night with headphones and today, I have to say that this is a nice little amp. It certainly has a better headphone section than my Denon. Through my RTA11TL's it presents as a little more refined in the mids and highs than my old Denon and seems to image a little better. The sound is spacious and sweet enough that I almost want to keep it. However, the Denon has it in the bass department and overall control authority over the speaker. With the size of the room, the DRA-835R effortlessly fills the room with sound while the 5004 seems a little strained.
    I should stick with my plan "A" and get a nice amp to hang off the Denon and later get a nice preamp to replace the Denon. Though, this little Marantz has me thinking about its bigger siblings.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • DeadFeat1
    DeadFeat1 Posts: 51
    edited March 2012
    I have been using the PM 5004 with my RTiA1s since November and must say that I love it. Works very well in my 12x13 room. It is rated to match up with 4 ohm speakers and is a high current amp. Nice example of how nice a less expensive, lower watt integrated can sound in two way system...highly recommended!
    Don't forget to enjoy the music...
