Need help identifying speakers
jfeino
I was cleaning out my closets and found a Polk ex502 box with two speakers in it. It is probably a pretty old box, and I am not sure if the speakers are ex502's or the speakers that I took out of the old car. The box does not say ex502a or ex502b, just ex502. I will try to load some pictures.
Post edited by jfeino on
those are not Polks... they are the factory units.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Yap, speakers are what someone took OUT of the car.2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1 -
You can tell that they are factory by that darker paper cone deal right in the middle. I don't know what the purpose of it is, maybe to direct the highs? Usually I've seen this when there is no tweeter in the system.Audison Bit Ten
Kenwood X595
Polk MM6501
Polk MM1240
Mtx 704x
Alpine MRX50
