bass has changed.
goingganzo
goingganzo Posts: 2,793
after getting my new pre my bass has changed it is still there butit is different i just cant put my finger on it. olny movies i have watched is lion king and atlantis.
i ste up and calabrated.
Post edited by goingganzo on
  • Frank Z
    Frank Z Posts: 5,860
    edited October 2003
    Gonzo,
    My Anthem allows me to adjust the bass using a feature called Room Resonace Eq. Does your new preamp have the same feature? I can adjust the lower frequencies to eliminate any spikes or dips in the low end, this allows for a smoother bass response.
  • bhenchey
    bhenchey Posts: 4
    edited October 2003
    Gonzo,
    When you say that you calibrated, which did you use--a setup DVD (DVE, Avia, Sound & Vision) or the Sunfire's internal test tones? The TGIII's sub test tone is pretty flat across all the frequencies v. the DVDs' (which usually center their tones at 40hz or so). In my room (and before equalization), calibrating to the Sunfire tone results in a much lower level of bass than using AVIA. If you used the test tone, try Avia (and vice versa). In my case, I had some nasty peaks and nulls that I trimmed out using a BFD as a parametric equalizer.
    Regards,
    Brian
    My HT:
    Mits WS-65869
    Rocket Loudspeakers--750(L/R), 200(C), 300(SS), 550(BS) and 150 (Sunfire 9.1 side-axis)
    SVS B4+
    Sunfire Theater Grand III
    Sunfire Cinema Seven
    Onix 2150 amplifier (side axis)
    Crown K1 (sub)
    Denon 2900
    BPT CPC (w/isolation transformer) [front end components]
    Brickwall 20 amp surge suppressor
    Panamax 4400 20 amp surge suppressor [amplifiers]
    Cables by Bluejeanscable.com and Signalcable.com
    What should I upgrade next?
  • bhenchey
    bhenchey Posts: 4
    edited October 2003
    Edited profile to show HT equipment.
    My HT:
    Mits WS-65869
    SVS B4+
    Crown K1 (sub)
    Denon 2900
  • polkatese
    polkatese Posts: 6,767
    edited October 2003
    bhenchey,
    great system you have there! rocket and PB4 got to be awesome. Any chance you could snap pics and post to system showcase? I am always curious with the rockets...
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • bhenchey
    bhenchey Posts: 4
    edited October 2003
    I'm planning to take pictures as soon as my custom entertainment center is installed (hopefully this weekend). I've been lurking on the forum since about this time last year, when I started off the whole HT-thing with Polk Rti70's, CSi40, RTi38's and a PSW650.
    I've made a few changes since then...
    My HT:
    Mits WS-65869
    SVS B4+
    Crown K1 (sub)
    Denon 2900
  • goingganzo
    edited October 2003
    thanks for the reply i did use the tgIII to calabrate i was a bit lasy to pull out my calabraton dvd. i will be getting out the dvd now to compare.
    ps how do you use the side axis speakers?
