to h/u dvd w/ hdmi and analog cables
leftwinger57
Hi guys,
This is for a friend of mine and he asked me i I knew how to do this h/u because he will be laid up for a while. He does not want to record just playback w/ the simplest of set ups. As I understand it he has a tv that is HDMI compatable and a DVR that is not, so could you please by the numbers explain how this would h/u and make him a happy guy.Hopefully this should not be that diffecult unless he's missing something which maybe you can fill in the gaps.
Thanks ,you have been so helpful in the past I know if it's possible you will talk me through it.......
The thread title and the text mention different pieces of equipment - does he have both a dvd player and a dvr? How about an avr?"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
I think he has a tv and a dvr and no avr at all2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
