oops
ipartywhenuhurt
so i accidentally bought a hd600/4...... is that too much power for the sr6500? I have read on some of the post here that many of u when dealing with 75 rms or a 100rms you advise to turn the gains down to a comfortable level. will 150 rms be too much for the sr6500 woofers to handle? im going to bi-amo them and use the full potential of the sr6500 woofers. and on the tweets i plan to not use all 150 rms. im going to go by ear for the tweets
Post edited by ipartywhenuhurt on
You will be fine. You would only use 150W at MAX volume. This would be rare. Even you turn it down by -3db you cut the power in half putting you at 75W which is plenty safe.Audison Bit Ten
Kenwood X595
Polk MM6501
Polk MM1240
Mtx 704x
Alpine MRX50 -
really???? just -3db and i lose have power O.o well i learned something new today i thought you tuned the gains on the amp till it was using all its power at max volume which i do plan to use :cheesygrin:
thank you pentoncm for the info and posting. i really appreciate it
SRs are rated for 125rms so giving them 150 is not too much by any means especially given that in real world you will never actually get 150rms.
So yes, absolutely no issues with this wattage as long as you don't boost or clip.2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1 -
ipartywhenuhurt wrote: »really???? just -3db and i lose have power O.o well i learned something new today i thought you tuned the gains on the amp till it was using all its power at max volume which i do plan to use :cheesygrin:
It is an important concept that many people just don't know about.
Twice the power = 3db which is 1.25 times as loud.
Twice the loudness = 10 db which is about ten times the power.Audison Bit Ten
Kenwood X595
Polk MM6501
Polk MM1240
Mtx 704x
Alpine MRX50
