Side Clearance for CSi A6?
Mark_1042
Mark_1042 Posts: 14
edited March 2012 in Speakers
Does anyone happen to know about how much side clearance is needed for a CSi A6 center channel?
I just ordered one, and in some of the pictures I noticed that the rear firing ports have the plates over them to reduce chuffing (power port technology, I believe). It looks like the air coming from the ports may get projected out to the sides a bit, and I plan on putting the speakers in a cabinet with only 1 inch of clearance on each side, and about 2-3 inches of clearance on the top. The rear of the cabinet will be open, as I plan to remove the back panel for that section.
The cabinet is also solid wood / veneer, so I imagine I may have to do some sound deadening if there are any resonance issues? (provided there is even room for it).
Post edited by Mark_1042 on
    F1nut Posts: 50,753
    edited March 2012
    I think you'll be fine.
  • mufsoman
    mufsoman Posts: 632
    edited March 2012
    Mark - I had my Csi A6 in a pocket in my cabinet set up. Pretty much same as what your describing with minimal side clearance and open back. I also have a closet right next to the cabinet on one side. The sound was great, but after getting a flat screen, I was able to eliminated the pocket and now the center channel is sitting on top of the cabinet, free and open. There was a definate improvement in the center sound. I think I just had alot of sound bouncing around behind the cabinet and against the closet wall. If you get any echoing or reverb in your set up, try adding a sound absorbing panel behind the speaker, that should fix it. Otherwise, enjoy !!!
    Parasound HCA-2003A & 2205A
    Front: Rti12's
    Center: Csi A6
    Side surrounds: Polk Rti A1's
    Atmos: Mirage Nanosats
    APC H15
    Power cords by Pepster, Morrow MA4 IC's, AQ Midnight, AQ Chocolate HDMI's[/SIZE]
    The rest is TBD.
  • Stilly74
    Stilly74 Posts: 194
    edited March 2012
    I have mine built into a wall unit. Never knew it needed air space on the top and sides.
  • Stilly74
    Stilly74 Posts: 194
    edited March 2012
    Does it Change the sound if it's got more room around it?
  • Geoff4rfc
    Geoff4rfc Posts: 2,477
    edited March 2012
    Stilly74 wrote: »
    I don't believe the top and sides have any affect on sound, and you already know the port guards on the rear ports allow you to get it close to a wall or anything of substance.
    I think as long as the A6 isn't recessed inside the cabinet, you'll be just fine. And, "you'll be fine" is exactly what the first reply to the original question was.
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
  • Mark_1042
    Mark_1042 Posts: 14
    edited March 2012
    Thanks again gents, it looks like it won't be a concern. I had thought having the port so near to something might cause "chuffing" (which I have never experienced on a ported speaker BTW, have only had problems with it on a leaky sealed subwoofer).
