Help !!
hlalanne
hlalanne Posts: 183
edited November 2001 in Technical/Setup
Hi;
I need some options and an explanation.
First the question, what is the deference between the RT2000p speakers and the RT2000i speakers?
I also need options on what kind of subwoofer to get for the .1 channel on my Dolby 5.1 system. My room size is 15x20x8.
My present speaker system is;
RT2000i for the fronts
CS350ls for the center
LS/FX for the rears
And a PSW50 subwoofer for the rear speakers. I have the sub wired thought the speaker connections.
Horacio
Wooden Delight Theater
9/11
NEVER Forget !!!
Post edited by hlalanne on
  • sgtgto
    sgtgto Posts: 310
    Hi:
    The 2000p has a 100W subwoofer amp, the 2000i has a 50W amp. There is also a difference in the material in the speaker cones I believe.
    A polk 350 or 650 sub would go nice with your system. Velodyne also makes a very good sub.
    Gary
  • skinny
    skinny Posts: 25
    i have a set up like yours i bought the polk psw 450 it goes great................
  • TrappedUnder Ice
    TrappedUnder Ice Posts: 975
    the 2000p and the 2000i have the same amp...just spec rated different. The main difference is diff drivers (blue) and a better xover.....
    Look around..there are many subs that will work well....other then Polk (not a polk sub fan myself):cool:
  • Jay M
    Jay M Posts: 54
    Hi Horacio this is Jason from Polk Audio customer service. The difference between the i's and the p's is the finishes. The i series, which is this years model, is available in either a cherry, maple or a black oak finish. All finishes are a real wood veneer finish. The p series, last years model, is only available in black vinyl. The only other difference is the tweeter in the i series is slightly clearer than the p series, but to most people it is hardly noticeable.
    Jay @ Polk Audio
  • sgtgto
    sgtgto Posts: 310
    Hi TUI:
    I have to differ with you on the amps. The specks say 100Watts for the P and 50 for the I's. You cant get any plainer than that. Those aren't different specks, those are facts.
    Gary;)
  • Aaron
    Aaron Posts: 1,853
    Actually I believe Thomas is correct. A year or two ago I believe the industry (or maybe just Polk, I forget) tried to "standardize" the amplifier power ratings. This way manufacturors couldn't artificially inflate their performance specs. I think this may have resulted from a law suit, but again, I forget. Whatever method they used to calculate the new power resulted in a lower rating. If you do a search in the archives I believe Polk Paul posted about this.
    Aaron
  • hlalanne
    hlalanne Posts: 183
    thank you all for the help.:)
    9/11
    NEVER Forget !!!
