Need some help with my new db525/650s
Knives
Knives Posts: 9
edited October 2003 in Speakers
Hi, this is my first post here. Anyways, my car has a sheet of plastic under the door panels[cant remember what its called right now], basically, should I cut holes in it where the speakers go or not? I have the db525s in there right now with the plastic sheets uncut and they are distorting very easily[I have the Alpine CDM-9803 model deck powering them right now and they start distorting when the volume gets to 15]. All help will be very appreciated.
  • dorokusai
    dorokusai Posts: 25,628
    edited October 2003
    You would have better luck on Car Stereo issues in the Car Audio section of the forum. Good luck on your problem.
    Powered by Dodge/Jstas/Sntsuperman are all helpful over there.
  • dave shepard
    dave shepard Posts: 1,334
    edited October 2003
    You will want to direct auto questions in the car audio section of the forum. But I would say yes you should cut the plastic sheet only as big as your speaker hole and use the speaker screws and the frame of the speakers to help hold it back in place, without it you could get a draft or air leak through your door panels.
    Dave
  • Knives
    Knives Posts: 9
    edited October 2003
    alright, thanks. and ill try the car audio section.
