AudioSource AMP210 for driving LSI7's
Hi,
I was looking to purchase the AudioSource AMP210 for $249 for driving my new LSI7's.
Was wondering if this AMP would be good for handling LSI7's ???
Thanks,
Ed
Thanks,
Ed
Post edited by elagrua on
As long as your amp is 4 ohm capable, you'll be able to handle them quite fine. This amp seems more than enough for that task.
I mean, my 50x2 NAD drives them easily in a moderate sized room... and I do not use even 1/5 of the overall power for my casual listening.
I do not know that particular amp, but it should do this job quite right.
Also, could you tell us about the rest of your system? Do you have any stands, pre-amp, receiver, cables and such?!
Speakers: Polk Audio LSiM 705, LSiM 703, LSiM 704c
Receiver: Denon X3500H -
I purchased the LSi7's for my secondary system. Which is and old Denon 2801.
My primary is a Denon 3805 with LSi15's and LCiC and 1000 sub....Denon 2310 CD/DVD player
And using AMP Adcon GFA 5503. Initially I did hook up the Lsi7 to the 5503 and they sounded pretty good but no where near what the Lsi15's sound like. Cables using monster 12gauge.
