Center Speaker Question
I just purchased the RM6005 speaker set and a new 6.1 receiver. Problem is the speaker set doesnt have the extra speaker for the rear center channel. I currently have a nice Mission Center speaker. I am not sure on the specs on it, but it looks to have two 5 woofers and one high range speaker. I was thinking about using the mission for my center channel speaker and using the RM6005 center speaker for rear center. Is this a good idea or will it sound bad?
Post edited by Chris07 on
I would suggest the Mission as the rear center. You want to keep your front stage as matched as possible. Bottom line, try it and see how you like it.
